ND-Photo.nl 's - Seat Leon ST Cupra 280
nd-photo.nl
3,790
62
The Netherlands
youtube.com
Changed the coolant expansion tank. After re-ordering a couple of times, I just went with the Nissens one. I thought it was a "G12" version and not a G13 with the silica bag. I removed the bag off course before fitting it.
Cap was also swapped out. Cheap item and its a mechanical item in the end (spring loaded cap)
AP1GczOo5A0DXMDbHffpLhry7YUUjCSDF0-Anf8qp8e0noyCwFtQE28T03Tk2LP-Tv9f4qklU2ydr_I6MsfVhXDx7oKg1WG2DR37WfvkOxQJRHgJs6xBmPx_MFsWubLaFW11BMq2VkhvoNieOaFaOiP8yoE9fQ=w1560-h878-s-no-gm
The old colored one
AP1GczOCRq4TBNmdXOomoF-QvpsawOMcoOgP7TDG7Aa1ly_o37AjnqbPBw2fI0yvTdfu-EZEDbxG8ACH20RJKuddJfW0sWi6kVsfhsmRR2E7wNOvco90GmumSBEi8d4N2jnkCyNYUzZSZjMTlZLdYch75vkKLw=w1560-h878-s-no-gm
Fresh items always look better :love:
AP1GczMn-27UrJTB_Z7_nlG6PuDSTGkL53grBCqOv4nC16xPIXRb2KROkccnzic9dj3W_Sr37OWY-iRtbvZfXMZouHhiSUIPM3OEjYHWXVyZLHwp-QAD0BfLqFQ9VesjAM6BYMbBsE1mY4H9XNmYMnddAocfjA=w1560-h878-s-no-gm
I will do a proper flush later, but added the G12 Evo from Kroon Oils
AP1GczPHGWUzVTXTZk00znq3bs0lrfcbskGx15O6b59Gtz3EwBKqHTCJrWfruGYKhtORNchibbBZpCHf-enzERYdUPmb9qpj2PsSZYLNdZZQgx47ZatkhixzAx8ys7yg8hmwhATdZwzzVAdkkY9EYPPnqyaVEA=w1560-h878-s-no-gm
All done!
AP1GczPH8eSf2thYTrZs9SmdabDda46EYSZfzsbyUOtSSz-Y4JKhuGOD3MG9boPnqIuxXN6q1Mj0NBI9WSFRAArvHyKsfrxfVolH57rUD5U-JJupmQg2ftWtsbSAdGz7Ub_WXl1BofJ-_X1QKs1dQK6zaqIlHg=w1560-h878-s-no-gm
nd-photo.nl
3,790
62
The Netherlands
youtube.com
With the subwoofer removed, I went ahead with insulating the boot. This made a big difference in sound deadening. There is already sound deadening material applied from the factory, but never hurts to add a little more.
Just by tapping the metal, you will hear what parts need the most attention.
Before:
AP1GczPdRbRP7heUOZp0hYUiOLJ3F648gdE7Cnp_wpp07yTY9lgUDJdU5QvShOlJr7YXzVR7E-EmIaRylnFRsdPnBNtvIPCxydJEt2hL2kPRCD2cepNEfKws-OSQVxs9YqKZ0IeGhGaqlhV4KajDNIiqFNmN1Q=w1560-h878-s-no-gm
After:
AP1GczO48iDeosjOpMrva0UmpXNW7s-n1OK_-UutOTLbUaGX-De28pjQh4WdsWkBtqMBGqjTYuPeeoCbSfoBCQcrNMPwkJjS_xRuCoq0mahB9yx-NHOVI9GxUBKbabVfePoERIpvQFSFBGfhhynuj_2OemP5yw=w1560-h878-s-no-gm
In the near future, I will order more and also apply it to the wheel wells and doors.
nd-photo.nl
3,790
62
The Netherlands
youtube.com
One of the first times when I needed to fill up. I was notified that the mileage could be a tad better. After this, I resetted adaptations and tried again :)
This was already heaps better than the mileage of the CLS55, where it averaged out on 1:6 :ROFLMAO: Also the CLS55 has an 80 liter tank vs 50 liters on the Cupra
AP1GczOwncgpo9DukQQ0lHN98kvwwdWIhHQjH2szvgcpIfVRo5BiF2yX7ju2Qe11e8Hs0SW-g6QWORK_x_4X1zTl35NoPd5QxGAlE3m-PITj6gX9Ax6Kl4LGFSvpMtcUxsjedmXAwaBavMNrPLeuGPHQyAdkPA=w1560-h878-s-no-gm
tracktoy
642
463
Have you played with the Individual mode settings yet, you can turn on coasting (cant recall the name on the screen) to allow the engine to drop to tickover when you are cruising on the motorway and are going down a hill
nd-photo.nl
3,790
62
The Netherlands
youtube.com
Went to the local Carglass for a "nano coating", which is essentially RainX but stays on much longer. I already tested this on the CLS55 and some other cars before that. Big adventages: less need to use the wiperblades and I almost dont need to scrape the window when it freezes.
Costs: 39 euro, and it stays on for at least the winter months which is a bargain for me (y)
AP1GczPi8p_wdyUlJUPKSAs5mGuqgGtg8N7qlBmLekYGf0LnPyrwtW6bk64PGP0iVp0okL3l1_KIrmLs5YPMXFNGH7as68KqgfHWPpIkc7V_3o8HaPk9cy7pyrI3JGi_Fc7xIxB2s7_mDvGyicjXSkFXdXKD3w=w1620-h911-s-no-gm
nd-photo.nl
3,790
62
The Netherlands
youtube.com
I discovered that recently, I was driving in Comfort until not too long ago. I put the engine behaviour in Comfort instead of Eco and tweaked some other settings, Individiual mode it is :cool:
But its not an eco car in my eyes, so I refuse to use it that way haha :LOL:
My latest fill was already better than this one, will post that in a later stage
nd-photo.nl
3,790
62
The Netherlands
youtube.com
Decided to replace the cigarette lighter replacement with another one. The one I installed first needed to be switched on everytime, which I think is a nuissance. I replaced it with another one, which also looks better in my opinion
AP1GczMXjUs3AofPJ3fCTMsm_2AI9ZpQwd70V0NmQ2hANUCEOfAe0r4ekgGcdFFnOkOu6pTxj5_3kRW1ZeDspTv6oPW-NOGdiI21WhraIY_kMNVMEjTCosS-nUm5x46Pp9yMfqfGPo5hjGEYoCrIjmswEnKDSA=w1920-h1080-s-no-gm
AP1GczN4LCxUum3uvDk6TSdfs9lo_pzlvz1X2Sa2ZD1SbWYviVDAyuPWfYzyXbBH5XQENK7zdXa5A9VmMfFPRce-gcNbtUK782F8E86UtIS3MH6KvU7OI99v7OeSYOwiIsNY3I0Q_b75QMgFMLeU0Pj7_wL2yQ=w1920-h1080-s-no-gm
AP1GczNNwsOymEnfhIPoaBCS8ksdjiZFcIPK7Nlt0rzmOS00IH65rY7aTPgzwf1agxYB8PiVFcZAim5R7CQrjNDWoumBb85IWjPZQ2_Ofrlnz0yrXShSLZso3oKjJeeqeod2PU1HRXar8tFeLPNFda_fzCFcBQ=w1920-h1080-s-no-gm
Reactions: tracktoy
nd-photo.nl
3,790
62
The Netherlands
youtube.com
The dial in the Sport menu feels useless for me. It shows absolute pressure (so inc ambient pressure) and not boost pressure/vacuum. Also the placement of the screen is not inviting for me and feels unsafe when flooring it.
So I decided to add a boostgauge from "Greddy". This is probably not the real deal, but I simply don't care because the quality is that good.. I have no other words for it. The gauge reacts very fast and the builtin screen has a very high DPI and good response time. When starting up, it has a staging/needle sweep routine, awesome :love: This unit works with a pressure sensor, instead of routing the vacuum hose all the way to the back of the gauge.
To easily tap boost pressure, I found this adapter which sits between the MAP sensor and intake manifold. Fitment also 100% and makes things easier.
AP1GczPnUwCNHZPqBF6Ksb6UbYkBnnxp29RagV0D5wvsRqCXsGOwVQbBKm_wtl3ggk5kohj_GlXwUe3x78-wa4hcxf662kSoCicDrb6--lAsPr6PQwV8GA66mWFYcrSSCy30FdrldLYi9djcXoB-K3Q-HivWXA=w1920-h1080-s-no-gm
AP1GczPTmBOEYE2hku1MG0Q0ouBYjzpjBoqbvw-rnKQoQCVixh7b4SeAI3rJU6HPWvlz7Z_Pg7mRkfLwJ8AbKxhk_VNpJ-xtzm0b24SDnz74Tbo_QX8iKDf_8-Kd0Bv97tPddV344f5xxuJibX6umv6cc3bzqA=w1920-h1080-s-no-gm
I bought high quality reinforced silicone hose from FMIC.pro
AP1GczPcJtGKPbKxPwoJ3UZej_QdScwKtPIshLM9cwqad0WS9PukW2wpwibRsef4IXTN3cOc0I120ITPfIqarQbp56pJwo7tqbzHabvm9y3Y2l6H-yJifnRL01poDjgw4NiCfH1d8iiqhJidyhod_BLnotIUTw=w1920-h1080-s-no-gm
MAP sensor off course
AP1GczPTF0DCjqEN3w_MONuzdtYnTVrM4Ge47fnbnzCC5wQmSd73mRtV2FUZTy1JJFCri9X6Vt4bezpraggmGr4c7Q1IwYA0CeD9wM8btCYQOfCyD-DyAvQA1iaULxxMY4_ZqPSt-eQU4puPBfSM8mFxHYs-6Q=w1920-h1080-s-no-gm
Sensor looks a bit dirty, I carefully cleaned it as good as possible, but it will be replaced anyway
AP1GczPkPFHhI0yW5De5_6WwtHXpS-7zQjtNbJ2wB7alzzxNORZSBBSclxteov8I78ZqjKBt2IsJu8erMu-bh_DIBMFI-xwEIDAj4U3bINOhHLpdtMgXajXPQuJLQgORHUWd45UiKpkvhHdArkLGk6w-pdOQLA=w1920-h1080-s-no-gm
AP1GczN_LIyvKsqM2dwiD51I63dscQevBoNDnFPrmTdHHQGeozD6rCCXMyrbUiFAVyeQmu-VSYYTOkebrDB3kO3rmRo6WJj9hCFCHRAfPJdr1InwTIrnWTbmf3tTfeQxyEnfc6D5doZSu21fDCR5f1F568hcyw=w1920-h1080-s-no-gm
The longer provided screw was a bit too long, so I used some washers
AP1GczNJmkXksTXzvnMscdDKK6acxwGWi6K1WOddDVUu_0SoBIJQ1MJkeL_6vvv-l7FT_hTJG6GOJwDBwLUHQw47SRkHaGEU8QU1uiiu4t51pWeqEvq7WgTttr_PEQXI9-cK-ConWpioMehluiGhUB6viYFOOg=w1920-h1080-s-no-gm
Enough room to route the reinforced silicone hose around everything
AP1GczNd8wPMS1atN0VN8xodXTx9zAHDwfC8r2TulQOaNXkSHLYBy05zTLu7C5UXlBxG0XB7wU2C_Vs_PluezybOUA08W0nztkVJk95SXo2Wcb-WhoB5iI1wIOfqEgvxICmyQYthc-vtQHzvrePkv54DSXg5IA=w1920-h1080-s-no-gm
nd-photo.nl
3,790
62
The Netherlands
youtube.com
Luckily, our Seat/VW brothers made it very easy to route some cable/hose into the cabin. Right behind the brake pedal for the drivers seat (in the correct place, J/K for my UK brothers ;) ) there is an unused bung. So punch through that, presto!
Work in progress
AP1GczO1Ex6MGxAYpA5ZnBH7NbD8SaGU5-ZQvghwbIFaxu_9tAJ3DRTEgrqIpxIjjaWxbTHQC3gzrP9yth0esCUiI4EPqVkR4KWXNEbS4MmLJwubLfpoNb0SO8kiTRsNm-EOvw7BtNrJ4afqFx_3bHSq2hCk1g=w1920-h1080-s-no-gm
Right behind the soundproofing
AP1GczMYL9x5b3XDRdinO1DNrw-oQjXN2HwZZyxFjs8SgyhczxOT_4eXeD_aAYpuBsJvaANHAiwvWfBvkJjWD5EI7U2GtB_65h8an-7vYCDX3LZbosawt9gnLEUyQET95TzISHiZQ3YkTUqPC8q5rhzqdmviVQ=w1920-h1080-s-no-gm
There it is!
AP1GczNoK5bdfLYcEpd_A4QMOVIOE-gp8dtLodrf9CsKjspbNWweQGEdnuJdQNQgXH399Ee8ahHb0r6S3YzYNMOQc63EvlGvX-x41Fqrw_sF1tUp9i0bxXCIAUnRRpGbVKM6yZYcRpwnXB5NT5mJbPY5LlvPQQ=w1920-h1080-s-no-gm
This is the bung, with partnr: 5Q0723753
AP1GczOIaFiqKfl8rMpRoDU8pt1xmf-MsNbK4ObEwlVzU0ysZCe4oniUMtFpRNAIEbwN152159QIhCHdm-TgLgD0oF3LTffgNVL70JOwgPcz4-DkCzi_mgvF6n2k5Fn_cUicMq30A5MXHzuh06sDBTzrqqgAqQ=w1920-h1080-s-no-gm
AP1GczP-njhIW8gID3glMHgxU3QLKTx24oMsHc9FrWuWRKF47k0DAo64gULkU65E5kNc3lhu_yxBybQijacuAHxlIh_Sh0YL6P3DOwuLs-NpYrjrMawKFMarz8kd8nD6eZHRYJNhTwpsWyM3y1n6s5vo3RKWfA=w1920-h1080-s-no-gm
After routing power (I tapped off the cigarette lighter fuse), it simply works! Screen has adjustable colors (also for day/night), the screen below is also able to show battery voltage etc.
Again, I am very happy with this modification :love:
AP1GczOQFlEotvmF6xrVVJZ1jfjjWLmFfF2FvQFVSh6uVcmfVOxIlzF-oYzFN9BsdYFRZyjiXdSJwtN3BO8jSRtEs-_3tnpoAMjQS1bcGjTvxqfWf3Lzcikni9SySeGU1jSr26SjL2CCVQ9b9VH-mpaEBnFGkw=w1920-h1080-s-no-gm
