Thermal box around battery - thoughts.......
nd-photo.nl
3,786
62
The Netherlands
youtube.com
I can highly recommend a battery monitor, then you are able to see what happens over time
More info: https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5068748
AP1GczOP1YtbHVc94hGuOFaOlnnOaBx24PUv2CgRLjw5gf0-Din_o4OQ2Jrr81kt_DpXiTiDl09OXC-zWsH1RGfR6sECSGXvKmdL9w66_ra2yEik4njFB1CvuAjcmFBKWWVjFTq7MqkSNdlgpVk08Sn2EFgB-g=w1920-h1080-s-no
LeylandVCDS
437
259
Leyland, Lancashire
Yes, that is my point - the OP has a 2.0 TDI - but has fitted an EFB.
The full option map shows a build code of J0V for the battery, and ETKA shows EFB 420A/70AH for the build code J0V on my car. Screenshots attached.
That's the exact battery that was originally in the car that I replaced.
The only change has been the uprated capacity of the replacement.
ViperSlider
153
98
Cardiff, S.Wales
Going back to the original question, the cover offers a thermal barrier for the battery so they are practical rather than cosmetic.
The sizes differ too so ensure you get the correct physical size for your battery.
RUM4MO
7,981
1,072
South Scotland
Also, I've always considered that the thermal barriers for car batteries was intended to limit the engine compartment heat from getting to the battery in hot weather and/or countries with higher ambient temperatures than UK.
One thing that might assist you in working out what is happening, is a small plug into "cig lighter" ie 12V Power socket, voltmeter, I've had one plugged into the socket on my wife's August 2015 VW Polo 1.2TSI 110PS 6MT for many years - it lets you get a better understanding of how the smart charging is working, and hopefully allows you to spot a dying battery before it lets you down.
Now, that 2015 Polo is coming up for 52,000 miles and it's original Exide EFB is still fit for use, okay it is weakening slowly (as checked at every annual service by me using a CTEK Battery Tester), but if I let the "do it's thing" with auto Stop/Start, the car's engine will cut out after driving 0.5 mile in winter temperatures - as long as I've kept the cabin fan and rear window heater AND seat heaters off.
This car tends to be garaged overnight though, essential to avoid lots of window clearing of frost and snow off car!
Edit:- I like the idea of having a battery monitor that you can view remotely though!
My older daughter's 2019 Leon Cupra also has an EFB - SEAT being a bit tight/cheap there I think, but her car is also on its original battery and I test it at annual services and it seems to be in good condition yet!
cuthound
51
27
Indeed, AGM batteries are actually VRSLA's (valve regulated sealed lead acid) batteries, which don't have a liquid electrolyte but recombine the oxygen and hydrogen evolved during charging to maintain electrolyte levels. Excessive temperatures and/or over charging results in the gas pressure inside the battery increasing which causes the valve to lift and vent the excessive pressure to atmosphere. As the gas is the electrolyte this significantly reduces battery life.
SuperV8
1,600
724
The genuine battery cover for your car: 5Q0915411E
Protective battery casing with cover
PR:J0V+TJ1, TR1,TS1+7L6
