Oil change question
Feb 13, 2023
49
I've got the message oil change required come up. I had this last year after 10k I think and reset it as it was coming up every start up. I took it to a garage who checked the oil level and they said it was fine. I ended up doing 19,000 miles without an oil change before I took the car into its yearly service but I was wondering is it ok to do that?
I thought it would show a symbol on the dashboard when an oil change is due, so I assume I can just carry on again like last year
H Rafiq
1,129
466
You need to change the oil every so often. Annually or 10k I believe, depends on your engine and if you’re on long-life servicing. Just because the oil levels fine, doesn’t mean you don’t need an oil change, you get me? An oil change isn’t dependent on oil level, it depends on mileage and time since last oil change.
Feb 13, 2023
49
All I know from the receipt is it had 4 litres of 5/30 oil, which was the same the year before which I did 19k on
H Rafiq
1,129
466
If it’s on the longlife service, you can do 19k miles between oil changes I think. If your warnings coming on after 10k, it’s set to normal servicing. I’d just drop the oil, change it and the filter, and you’re good for another 10k.
SRGTD
2,581
1,426
IMHO if going up to 19k/ 20k miles between oil changes its important to ensure the correct spec oil is used and it’s one that meets the approved VW standard for longlife servicing.
Feb 13, 2023
49
I've checked the service book and its got longlife sevice ticked
nd-photo.nl
3,719
39
The Netherlands
youtube.com
Longlife service is the main culprit for a lot of issues. Change the oil every year/15000km, whatever comes first. And off course, use a proper brand ;)
After using the oil for a while, it starts to degrade, that is what @H Rafiq is pointing to
Reactions: Mr Pig
Feb 13, 2023
49
I usually have a car service and mot together once a year, but as I've been driving more miles than normal I wasn't sure what to do, leave it like I did last year or not.
I'm wondering now whether its worth having a car service instead of just an oil change. (I'm useless with cars and can't do this sort of thing myself)
tracktoy
621
445
As everybody has said make sure you use the correct oil.
As an example this is the various items that my pre facelift car needs servicing so its not just oil and filter change but it obviously depends on your model of Leon.
Work RequiredAt MillageAdditional Notes
6-gear DSG gearbox 0D9: change
the oil and filter
Every 60,000 km
37,300 Miles
Panorama roof: check operation,
clean drains and lubricate guides
After 3 years / max 60,000 km
and then
every 2 years or 60,000 km after that.
Engine Oil FilterFlexible oil change interval then every 18,641 miles / 30,000 km or 2 years
Fixed oil change interval, Maximum every 9320 miles / 15,000 km or once a year
Air FilterEvery 55923 miles / 90,000 km or 6 years
Dust and Pollen FilterEvery 37282 miles / 60,000 km or 2 years
Oil Change ServicePR QI1 - every 5,000km
PR QI2 – every 7,500km
PR QI3 – every 10,000 km
PR QI4 – every 15,000 km
PR Q17 – every 30,000 km
Spark PlugsEvery 37,282 miles / 60,000 km or 4 years
Front axle differential lock oil changeEvery 3 yearsPlease note many main dealers don’t deal with cupra’s and do not understand about the front diff, this needs to be looked after.
Brake fluid and clutch: RenewAfter 3 years (first time) and then every 2 years
Key Fob BatteryWhen warning message shown on the screenCR2032 Battery.
How to video can be found here
  • Love
Reactions: nd-photo.nl
R3k1355
1,828
262
Yorkshire
The manufacturer says you can do 19,000 miles on long life oil. They also don't care if your engine explodes once it's out of it's warranty period.
19,000 miles is way too long to run oil IF you want long term reliability. If you're happy to fix/repair the problems that it'll cause then crack on.
Mr Pig
2,740
977
No way I'd do 19K miles between oil changes. Not a chance.
Many manufacturers introduced these long-life service intervals years ago. The fundamental goal was not to improve reliability but to make the cars more attractive to fleet buyers as it reduced the service costs. If you google you'll find out about the issues it caused later in the car's life, off the top of my head I can think of serious issues with several BMW engines.
Bottom line is that skimping on serving is never a good idea. Even if you don't suffer directly for it, poor servicing could well effect the future value of the car and make it hard to sell. I've walked away from several cars because of gaps in the service history. I went to see a Mazda MX5 a few years ago. Two year gap in the history. Girl said it had been serviced but had no record of it. That car still isn't sold! It sits a garage gathering dust. They'll have to drop the price a lot to get it away, certainly by more than it would have cost to just service the damn car.
BillyCool
714
287
Leicestershire, UK
When I first got my Leon I was doing 20k miles a year and thought the "long life" service interval was ideal so it only needed one service a year. My mechanic soon changed my mind when he said that 20,000 miles for any TDI on the same oil is quite a stretch. It was another VAG brainwave to appease fleet buyers as they could claim longer (cheaper) service intervals. Don't worry about the long term mechanical implications. Any fleet car would have gone through the auctions by then and be owned by the likes of you and me before they went wrong. VAG don't care.
So - I now change oil and usually filter every 5,000 miles. It's personal choice - I do it myself in an hour and it costs about £50.
I'd agree with the other comments that ideally you should be looking to have an oil and filter change every 10,000 miles. It is a long term investment in the health of what can be a slightly fickle engine. I'd rather have my Mk1 PD engine than the EA288 lump I currently have.
mty12345
3,949
573
bristol
As others have said, no way i'd ever go over 10k on any engine and I change mine at 5k or 6 months. Also depends a lot on the type of miles you do. If you do lots of motorway commuting in 6th gear, then that's fairly easy on the oil and 10k MAY be ok. If you do lots of town driving with short trips, or drive it hard, then i'd change it at 5k.
G.P
1,275
41
Worcestershire
I think they were the first with the 20k service's back in late 70/early 80 with the 90 5 cylinder engine..
