passenger without warm air
Dec 2, 2024
Hi. i have a 2013 seat leon my car only blows hot air out on the driver side and the passeneger gets cold air. I don t know where to start looking tnx
cairus
616
193
There are always new things like this. But I can't guarantee that my assumption is correct. My experience has always shown this to be the case so far.
MartinThorn
74
24
ok tnx i will try it and hoop to not break my car (y) and do you myb know what is the best way to clean it
Experience of some on here is that it is better to replace the heater matrix since often cleaning it is a temporary fix only and getting to it even to clean it is quite difficult.
Replacement at home takes a few hours.
Here's when I did it: https://www.seatcupra.net/forums/th...ething-problems-but-sorted-in-the-end.476713/
Might also need to remove the 'bag of beads' in the coolant header tank (or fit a new tank without such a bag).
MartinThorn
74
24
So shuld i try to clean it to cheak if it is the problem and the replaci to be 100% sure that i have fund the mistake
Up to you, but replacements are not that expensive (or they weren't in the summer!). Cleaning it might work for a few months or longer if you're lucky!
SuperV8
1,560
692
If you are doing the work yourself - by all means take out the heater matrix and back flush it with mains water - and see if this cures your problem.
Lots of posts on hear regarding heater matrix.
I found the usual garden hose adapters fit will in the matrix allowing good pressure.
I flushed my matrix many times hoping each time would be the last, but it turned out to only be a temporary fix for me - I eventually brought a new matrix and haven't had the issue since. You should flush the whole cooling system first before fitting your new matrix.
Reactions: Walone
