Side mirrors unfold via ignition on (MK4 model setting?)
mrtndbs
28
Apologies if this has been discussed before, can't find a definitive answer.
Does anyone know if it's possible to set up auto side mirrors unfold via ignition on?
FOR MK3 models, I have read some threads where this is a setting in 09 Central Electrics > Adaptation > Spiegelverstellung >
-Funk Spiegelanklappen: Active
-Funk Spiegelanklappung Modus: By look command via remote control key
-Menuesteurung Funk Spiegel anklappen: Active
-Profilfunktion fur Anklappung der Aussenspiegel: Active
-Spiegelanklappung geschwindigkeitsabhangig: Active
-Signalisierung_Spiegelanklappung: Not Active
HOWEVER, IN MK4 model, all I have is the following set of settings under 09 Central Electrics > Adaptation > Spiegelverstellung >
-cp komfortbedienung spiegel anklappen
-spiegelanklappen bei verriegelung
-spiegelabsenkung bei rueckwaertsfahrt
-menuesteuerung spiegelabsenkung
-spiegelverstellung synchron
-menuesteuerung synchrone spiegelverstellung
-menuesteuerung funk spiegel anklappen
(all set to active)
I am only able to fold and unfold via locking. I would like to FOLD upon lock via key and UNFOLD via ignition start.
Does anyone have any ideas?
Many thanks, Martin
KoNG
525
111
London
This would needs to be changed what options you have there?
mrtndbs
28
Thank you mate, but upon throwing the phrase into google translate - wouldn't disabling this just disable the auto fold when locking? (translation: mirror folding when locking). Thanks, M
KoNG
525
111
London
Check what options you have there. In my opinion is no point to change it as i have a puddle light with welcome message HOLA 😁
cairus
1,062
363
bitte zeigen Sie mir die Unterpunkte dieser Anpassungen
mrtndbs
28
cairus
1,062
363
please show the rest of it too. I think this point would really be removed... I'll look tomorrow when I have a car available
mrtndbs
28
I've been investigating with ChatGPT and perhaps on MQBEVO platforms, Module 42 (Driver’s Door Electronics) and Module 52 (Passenger Door Electronics) may hold the coding options? I'm sharing backup data from my vehicle:
42 Driver Door
System description: TSG FS
Software number: 5Q4959593H
Software version: 0692
Hardware number: 5Q4959593H
Hardware version: 010
Backup name: Driver Door
Long coding: 00351522D000020000001000
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959592H
Software version: 0691
Hardware number: 5Q4959592H
Backup name: Passenger Door
Long coding: 00351122DC00020000001000
mrtndbs
28
mrtndbs
28
I have thoroughly tested STG 42,52 and 09, no setting or coding or adjustment brings success
Ah that’s unfortunate. Well, we tried.
I found the next best thing to mimic the desired setting is to switch the mirror position adjustment knob (near the window opening console on the driver’s door) to fold mirrors upon exiting the car. That way, upon next unlock, mirrors will not unfold. The automation aspect is of course absent, as one has to remember to flick the knob out of fold position before departure and back to fold upon journey end before exiting the vehicle.
