Passanger door not getting power
Nov 26, 2024
7
Hi i got seat leon 1m 2003.
Problem is i got no power to the door lock front passanger. I have changed the lock 2 times did not work and no sound that it would try to lock or open. clearly i did something wrong cause the door is jammed closed. I was thinkin maybe the wiring got something to it? and where is the next connection for the door wiring? and to add either midbass or discant aint powered either but the window is getting power and working. Im new to working on cars and sorry for inproper english.
Nov 26, 2024
7
Update
I got it open and fixed the inside llever to be working the wire wss not correctly but im still not having any electrisity to my door mirror and glass lift works fine but lock, midbass or discant is not having any power. Talked with friends and they suggested its the door wiring thats the problem. Any knowledge where is next connector? tried to look up but havent had any luck.
Battoussai
498
160
Portugal
Hi there. Do you have a voltimeter? If so, check the cable that meets the confort module on the door. The lock gets power from there. What do you mean the midbass? - Do you mean the door speakers (bass and/or tweeter)? Those get their power from the radio unit.
mty12345
4,040
644
bristol
Hi mate. There is a connector where the door wiring joins the body wiring. I would check here.
Also check inside the Rubber piece where the door opens and closes. They can get broken wires in there.
Reactions: Battoussai
Nov 26, 2024
7
hey I have voltimeter the doorlock did not get power where the wiring goes to lock module ill have to check where door wiring meets bodywiring. the smaller door speaker doesnt work either but the bigger speaker on the door sound just a little music but not all it should.
mty12345
4,040
644
bristol
No worries. You may find that there is corrosion inside the connector, if so you can probably clean it with IPA (isopropanol)
If the wires are actually broken, i would just cut out the broken areas, and solder in some new wire to replace the broken areas. Then use tape or heatshrink to wrap the wires back up again. If you want to replace the door loom then i think you will be able to find a used door loom on ebay or similar. I don't think they are available new any more.
Nov 26, 2024
7
If the wires are actually broken, i would just cut out the broken areas, and solder in some new wire to replace the broken areas. Then use tape or heatshrink to wrap the wires back up again. If you want to replace the door loom then i think you will be able to find a door loom on ebay or similar. I don't think they are available new any more.
yes i need to check it out asap and thank you too!
