Headlight issue 2018 plate Leon
Apr 24, 2023
Has anyone else experience this haze type what seems to be in the inside of headlight. Doesn’t affect the light working, wondered if would pass MOT still? Still have a approved warranty on car but is it worth it? Will they do anything?
SRGTD
2,664
1,505
The haze is not uncommon - I’ve seen the issue raised on other forums - and on this forum before as well (see discussion topic at the link below). What you’re seeing is probably crazing of the polycarbonate lens caused by the UV protective coating on the lens degrading over time. I’ve also seen it suggested that some harsh car cleaning products might also cause the UV protective coating to degrade.
https://www.seatcupra.net/forums/threads/crazing-micro-cracking-headlights.472232/#post-5029677
Apr 24, 2023
Hi thanks for your comment, would using cleaning products on the outside sort anything as the issue is on the inside?
Would this pass an MOT or is it likely to worsen over time do you think?
SRGTD
2,664
1,505
Although the crazing appears to be on the inner surface, I’ve seen it suggested it’s actually within the polycarbonate material rather than on either the inner or outer surface of the lens. If this is the case, then IMHO cleaning or polishing would be unlikely to remove it.
it might be worth doing an internet search on ‘polycarbonate headlamp lens crazing’ or a similar search. Some of the search results will hopefully cover the effectiveness (or otherwise) of cleaning and polishing. If you do attempt polishing out the crazing, then ensure you apply a protective UV coating as a final stage (can be bought as an aerosol spray).
Sorry, i don’t know whether crazed headlamp lenses would result in an MOT fail; if the headlamp(s) light output and beam pattern isn’t affected then I don’t see that it should, although that’s just my view. It might be worth asking at a local garage that carries out MOT testing for their opinion. My last two car’s headlamps had very minor crazing and they both passed years 3 and 4 MOT’s without issue, but the crazing was very minor.
Mar 19, 2025
As for the MOT, you're right to check with a local garage for their opinion. If the crazing doesn’t affect the light output or beam pattern, it’s less likely to cause a fail, but it's always best to double-check with the experts to be sure. Some minor crazing, especially if it's not obstructing the beam, might be overlooked in the MOT inspection, but anything more significant could potentially lead to issues.
Mar 19, 2025
Sorry, i don’t know whether crazed headlamp lenses would result in an MOT fail; if the headlamp(s) light output and beam pattern isn’t affected then I don’t see that it should, although that’s just my view. It might be worth asking at a local garage that carries out MOT testing for their opinion.Try your luck and win big https://bizzocasino-au.net/ My last two car’s headlamps had very minor crazing and they both passed years 3 and 4 MOT’s without issue, but the crazing was very minor.
It's worth searching the internet for “polycarbonate headlight clouding” or similar to see how effective cleaning and polishing is. If you decide to polish, be sure to apply a UV protective coating at the end of the process.
