New expansion tank?
pauly1299
108
13
SEAT Parts have new expansion tanks without the silica bag, for less than £20. Is it worth fitting one on a 2019 CUPRA R with only 25k miles? The car has got SEAT warranty on it, might deleting the silica bag be an issue if there was a claim.
RUM4MO
7,975
1,067
South Scotland
If it was me, I'd plan on replacing the coolant that is in it now with G12evo - after replacing that reservoir, your warranty company couldn't hold that against you as both parts are joint replacement for what is in there now.
Edit:- maybe share the part number of the replacement reservoir for the benefit of others who are considering doing this.
pauly1299
108
13
Just look on seatdirectparts, it's listed on there. I have the SEAT service plan on my car, so it's the SEAT warranty. I'll ask the dealer about the new expansion tank and G12evo coolant, nearer the time of the next service.
ViperSlider
141
95
Cardiff, S.Wales
According to the sites own model search for mk3 Leon Cupra, 5Q0121407AA - Currently on sale at just under £19 on Seat Direct Parts
With that being said, ETKA shows 5Q0121407M as the correct updated tank without the bag for my 2016 mk3 Cupra 290, which is also on sale for just under £19
Reactions: Compo1
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
Why not just pull out the bag?
Depending on which bottle was fitted at the factory - you can't access the silica bag/capsule
nd-photo.nl
3,722
39
The Netherlands
youtube.com
Its a bit of a hassle, but you can remove the silica bag. Just make sure you have G12Evo in your system, as this contains silica. G13 should not have the silica added and relies on the bag.
Use angled needle nose pliers and you are able to remove it
AP1GczOWp6YP9v7-xBxlzOosmPDtehT3WN1tKiZpjkob_sQK48Ms53-blf77l72IK3IA1hSkYxI83ZhtcH3IK47SKAhtBQ9kF7cf34momkNIHDYAQSieotp1k712IXXCi5MGEh9pZCcVi-5QSzW5jy75OFBEBQ=w1620-h911-s-no-gm
AP1GczMJJM7xEK2OY9Q97-WGzwJt3mka48Bu-iELSR1MDdi9iSC8ZlnPSWZ9hjQ_YUImTy8jO9Ba9FjFErVIlRsvHzSyHwRGWF9v1iFpKg3AHbeTP1gQcU7VUS9ExjiPkpAcf6gNkisqbcqBdgB5IMTOn_RtZA=w1560-h878-s-no-gm
SuperV8
1,580
710
Not ALL tanks have this 'tea bag'!
By all means - if you look through the filler neck and see a 'tea bag' you can carefully remove it and change your coolant to G12evo - but my tank, like the image above has a self contained silica bag - which is not accessible - you'd have to cut the tank open to get to it - so in this case you'd need a new tank without 'mit silicate'
I'm not convinced these type of tanks can leak the silicate - as it is contained in its own chamber - but new tanks aren't expensive so might be prudent to change when you change/flush your coolant.
Reactions: nd-photo.nl
