Nov 6, 2024
7
Hello. In my car settings I do not have the Wifi Hotspot option. According to the instructions, there is a Wifi module in this car. I have a Seat Connect and it works normally. I also purchased a data package. I have System Media 8.25'.
Probably need the firmware (XXX) and hardware (H??) build plus the FeCs (long menu button press, installed / available) for people to get their teeth into that. The FeCs are the way elements of the firmware can be un locked. Possible wifi is there but not turned on, but if it's not there and you bought data then if it's been decided it's not going to work like that then it's those three parameters of significance. The manuals tend to be universal to the model range which may overstate what's actually fitted to the car.
@East Yorkshire Retrofits any comments. Who's got it and what are those three parameters if it isn't a menu toggle to turn it on.
good morning. I would personally look at the adjustments of the 5F first. STG 5F ---> adjustment ---> WLAN must be active. The same is true for WLAN 5Ghz
FeC Code is normaly 0x00070700
HW Number normaly XXX054830 (Face lift maybe a other Number)
Date of Produktion? Because the regulation UNECE
I thought it might be related to searching for coding eggs
Not sure whether that's been withdrawn now.
Thing is to ask the dealer why isn't it there.
I have a Info
SW Train MEN3_EU_SE326_P1114L
MUSW 1514
Device NR 5fj035869a
Hardware 042
It's 2021 manufacter but its model for 2022 year. I have OBD11 and i on all option in 5F with LAN.
The first photo is instaled.
the vehicle was delivered without WLAN/hotspot function according to VIN
It's chance to her this function. Beacuae the system have this, but it's inactive. And manual said that's ale cars have a wi-fi function
I have the same system in my ibiza. You have wifi but you can only use if for wireless android auto or Apple carplay. It's not possibly to use the wifi as a hotspot to share Internet. In the manual they also have the system with larger screen. You will need that one for Internet connection.
Well the Ateca in 2017 form had the wifi transmit function taken out although you could enable it. It's like the router functions you find in home WiFi. In the Ateca they had suppressed the toggle menu so the manual didn't tally. This was the time when Seat had dipped it's toe into apps. They released the apps but could not connect to the car ?. The Arona may have this menu suppressed...
This one:
May be something like that.
Ok. Then why i don't have android auto wireless? I make a everything on OBD11.
If you have obdeleven, check module multimedia 5f go to adaptation, search for function configuration connectivy
I will attach a screenshot of my configuration. If you don't have android auto enable try to enable it and maybe you get wireless android auto.
I don't think it's possibly to activate a wifi hotspot in the entry level system, I tried and I have searched alot about it.
Reactions: cairus
