Guest we are excited to announce we are now stocking CUPRA and SEAT valve caps! order now from the store
I have looked around ETKA using the handle part number and there is no information on the 8-pin connector yet@grabania
where, my dealer with ETKA Europe probably can't find an 8 pin connector. I have now written to my contact in China...
This is good info for the 8 pin connectorFew minutes in ETKA and I think that I found it. The most promising one is 3G0973708 (blue), but there are also 3G0973708A (white), 3G0973708B (gray) and 3G0973708C (violet) variants. ETKA says that 3G0973708 is used in Skoda Enyak for Keyless and its door handle (8Y0959121) indeed has 8-pin connector
Edit. Skoda Enyak and Octavia probably uses 3G0973708A (white) which would match color of a connector in the door handle.
I know as I am the author of that post I just wanted to know which one of those connectors are used in AliExpress wiring for handles with Keyless and lightsThis is good info for the 8 pin connector
Thank you!8 pin connector white 3G0973708A
Don't worry, it's just a reflectionBut you don't want to tell me that you are happy with the paint job?
Same handle, same spot from different anglesI think you misunderstood me. It's about the paintwork. It looks terrible in the marked area...
