Power steering headache
madocks
16
Trying to help my son fix his car, started off with intermittend PAS, light on dash with engine running which would clear after a few mins.
Taken to garage, codes read;
U111100 - Function restriction due to missing message - Passive, sporadic
01309 - Power steering control module - No signal
So far;
Have changed pump​
Have changed battery​
Have checked fuses above battery and all seem fine​
We have not coded the new pump, but google suggests that the PAS should still work but a light remain on the dash?
All codes are clear, drove for 20 mins and no new codes.
Currently seeking a VCDS locally for a proper scan.
Does anyone have any thoughts? could it be coding issue?
SaracenUK
107
So far;
Have changed pump​
DM222 is probably your man
dm222
1,482
49
never seen that error before, you probably have a wiring problem, also I think besides the fuse above the battery, there is one fuse inside the car that is for steering
when its a code issue the pump usually runs at a lower RPM providing less assistance and there is a light on the dash
when the coding is wrong the pump is always running at idle ~1000rpm, when everything is coded correctly the pump rpm increase up to 4000rpm according to the steering wheel movement and speed of the car, the lower the speed of the car the higher rpm is necessary for a effortless driving experience.
Is steering as stiff on idle as when engine is not running? If it is the same it indicates the pump is not running at all, then either you got a bad one or have fuse /wiring problem
madocks
16
Hi, steering may be a little better when engine running, hard to tell
I now have vag com........ my plan is......
Run vagcom diagnostics and dependant on error go from there
Check vagcom to see steering angle vs steering wheel
Remove bumper from front
Plug old pump in and take code
Plug new pump in and apply code
Search for any cable issues by bumper
search for any cable issues under battery tray
Do you have any other suggestions? or do you have any tests to check wiring issues? continuity checks perhaps
dm222
1,482
49
that would work... if the old pump can still connect to CAN, sometimes when they go bad you cant even connect to them
to discard a coding problem you could try this codes on the new pump 11211 and 10111 (those are the default codes for most ibizas)
if one of this code solves and steering is too light try to change the 4th number 11221 or 10121 (some ibizas come with codes ending with 21 instead of 11, I think FR but not sure)
madocks
16
Ok so update........
Using VCDS cleared all faults, power steering light went off, test drive. Sorted.
Used the car for a bit, then light back on again. VCDS as follows;
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 422100
Shop #: WSC 00049 770 00142
VCID: 70EF65C7A3A31A1633-8024
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 127
Mileage: 148505 km
Time Indication: 0
Date: 2019.04.02.
Time: 00:02:49
Here is a load of diagnostic pics too
madocks
16
Thanks for the help, if you could take a look at the above post i would be thankful
dm222
1,482
49
everything on that seems ok, except the voltage seems a bit high but no idea what could cause that
the most likely scenarios at this point are:
1 - contacts with the pump are not properly clean
2 - you have bad wiring
3 - the pump you got is also defective
where do you got the pump, I once bought one that had water inside, they have a hole inside the power plug and if they are not properly stored they fill with water and get damaged, which could be the case it worked for a bit and then failed....
also so you know the pump is taken from a car with high mileage it has 4276 hours of use but that alone doesn't mean its bad.
madocks
16
  1. Checked all wiring and happy with it
  2. double checked fuse on battery
  3. cleaned all contacts with electrical cleaner
  4. reset all codes
  5. topped up power steering fluid
  6. stuck battery on charger, charger went green and fully charged within 15 mins.
Pump still tempermental. Decided pump faulty........ not going to faff around, giving up. Car isnt worth enough to contine playing, son was going to part X it anyway.
Thanks for your help but we are giving up
