Is that it? It's quite common now and the drl's are dimmer than when the car is on.Put light switch on to sidelights. Yes it will drain the battery after a period of time.
Yes but I can't say that I've seen this myself on any VW group vehicleIs that it? It's quite common now and the drl's are dimmer than when the car is on.
are you sure? I think he means the park lightPut light switch on to sidelights. Yes it will drain the battery after a period of time.
Yes, parking light is 1 side light only, not DRLs.are you sure? I think he means the park light
The cars I've noticed with them on are both lights but dimmer to when you unlock the car or when car is started.Yes, parking light is 1 side light only, not DRLs.
Yes, I am sure. I don't make a habit of repeating myself so this will be the last reply.Sure?
what I have in mind is the daytime running light which is also the parking light
If you leave the light switch on side lights, they are dimmer than when on as DRLs, that's not coding that is their designed function. Sounds like you have a large amount of people leaving their side lights on in your area lol.The cars I've noticed with them on are both lights but dimmer to when you unlock the car or when car is started.
Have seen this just today on a tiguan and rs3.
Also seen this before on a 4 series.
On my car I've just tried this, if you leave sidelights on and then lock the car the brightness is the same as when the cars on so it can't be that.
Must be something in coding.
I'll take a sneaky pic when I'm out an about.If you leave the light switch on side lights, they are dimmer than when on as DRLs, that's not coding that is their designed function. Sounds like you have a large amount of people leaving their side lights on in your area lol.
Do you have any pics of what you mean?
