Halfords fitting on subwoofer? 2024 ateca
GringAddict
31
Manchester, UK
Hopefully someone can help answer this. Normally I wouldn’t trust Halfords with anything other than an online order but my cupra ateca has the standard sound system which is just terrible. Halfords offer fitting for £10 on subwoofers, ones that supposedly can work off standard speaker wiring. Will this work seeing as it’s SFD locked infotainment? Can the speakers be swapped out for better performance ones of the same size too?
Thanks in advance!
Jan 14, 2025
Thanks in advance! https://www.seatcupra.net/forums/threads/halfords-fitting-on-subwoofer-2024-ateca.476711/slope
Verifying whether the subwoofers are compatible with the SFD-locked infotainment system of your Cupra Ateca is absolutely worthwhile. It may depend on the particular equipment, since some users have experienced difficulties with comparable configurations while others have had success. Regarding changing the speakers, you should see an improvement in sound quality as long as they are compatible and the same size! Just be sure to investigate the appropriate components. I wish you luck!
