Diffuser not sitting right
Yoshi
78
32
Hi guys,
I've had a rear reiger diffuser fitted but one side seems to be slipping out by 1-2cm ide say. Ok if I push it back on for a few miles but then slips again. The one side fits fine.
Not sure if I should use something to help it stick when pushed back in?
There's 3 screws holding the diffuser between the two exhausts but nothing between the exhaust and outside edge of the car. I know usually there is 1 screw each (between the exhaust and the outside edge of the car), there is on the original diffuser but can't actually see a hole to screw into even if I drilled one into the diffuser.
Any ideas?
H Rafiq
1,165
492
Can you take it off and make a hole for the sides and put a screw in each side?
Reactions: Yoshi
Yoshi
78
32
Can't see anywhere which the screw would go through to.
I have been recommended tiger seal so ile try that where i've circled on the photo then push on and leave for 24 hours.
