Reversing camera
rohank99
36
12
Got an SE Leon 2019, was wondering if it’s possible to fit a reversing camera and how I would code it into the infotainment system? I’ve saw a few videos on YouTube but none actually explain how it’s done or link any products so ive not got any clue if it’s able to be done and how so
LeylandVCDS
494
287
Leyland, Lancashire
Yes it is possible. My 19 plate estate has had a high line camera retrofitted, with the moving dynamic lines on screen when the steering is turned. It needs to be connected to power, ground, and into the canbus system, and the steeering angle sensor if you want the high line, it will then need to be coded in with VCDS, Odis-E or VCP and posibly calibrating as well. Quite a big job, but worth the effort.
Reactions: Sergey
May 13, 2024
Could you advise WHERE can I install the rear camera on my Ateca ?
Is it possible to install a 360 camera on Ateca?
May 13, 2024
We can also install area view
Seat said installing the 360 camera on my Ateca DF68PXJ is not impossible.
But how much does installing a rear camera (170-180 degree) in East Yorkshire retrofits cost?
Anything is possible :) . Area view is just expensive
LeylandVCDS
494
287
Leyland, Lancashire
The highline camera I had fitted to my Leon ST is mounted on the bumper above the number plate where the lowline camera sits. Dynamic guide lines which move with the steering wheel and multiple views are fully available
Reactions: Sergey
