As I said earlier some folks from Russian forum did this and list of parts that’s needed to be changed in mk3 is rather expensive: Formentor wheel with extra buttons, airbag loom from Formentor (1 or 2 more pins, I don’t remember), Formentor slip ring, newer BCM and Gateway, not mentioning required coding, component protections, immobiliser and parametrisarion. Also this mod is useless unless car is equipped with driving profiles and kessyI just found this topic, might give them a shout to activate the cupra/engine button.
Would you be interested in an upgrade to a Leon/Cupra Formentor steering wheel?
We're currently waiting on parts however we'll soon be offering upgrades for the mk3 Leon/Ateca which will allow you to have a Cupra Formentor steering wheel as pictured below! The wheels feature onboard cruise control/driver assist buttons aswell as an option of having a heated steering wheel...www.seatcupra.net
@grabania Thank You very much for this hint. Now everything works excellent.
I've tried to enable it in my MK3 but I was not able. My guess is that you need to flash HVAC firmware from Skoda in order to enable this.Probably somebody knows, like on Skoda Kodiaq when You press "seat heating button" on Infotainment display pops up heat level, and also steering wheel heat level soft buttons. Is it possible to do same on Seat?
There is no OEM option for MFSW buttons to be red. You can even google something like “Ibiza 2023 interior” or “arona 2023 interior” and you will see mix of white buttons on the steering wheel and red buttons everywhere else, even in the new Seat cars.Can someone help me with this one pls ...?
Steering wheel work well but i want the buttons to be red ? Is it possible?
I have seat leon 5f and mib 1.
You should be able to code it in module 08 regardless of heated steering wheel being installed or not.I have one last question... I will add the loom tomorrow, but i wanted to enable in vdcs the heated steering wheel... But even if i see the bit i can't enable it for some reason? Is it because it need the loom installed? Or is it bc my car doesn't support it ? (The new steering wheel was not installed too !)
It seem, i have the auto button ,But i don't have the menu in the screen View attachment 40677 View attachment 40676
Look aboveYou should be able to code it in module 08 regardless of heated steering wheel being installed or not.
How does your HVAC panel looks like? Is it automatic or manual? I've heard that automatic HVAC is required in order to make this work
Relax! There is a lot to check and change in order to make it work, especially if you have installed used parts. My guess is that you have coding for accessories that your car is not equipped with. That's why cruise control is not working and you have those warnings on the dashboard.And i have a issue with my cruise control not working anymore and another one...
I alway forgot to it the reply buttonRelax! There is a lot to check and change in order to make it work, especially if you have installed used parts. My guess is that you have coding for accessories that your car is not equipped with. That's why cruise control is not working and you have those warnings on the dashboard.
First of all what kind of cruise control do you have, normal or ACC? Look in Module 19 (Gateway) -> Adaptations -> Multi Function Steering Wheel Control Module - Version and change it accordingly to you equipment (GRA or CCS for standard cruise control, ACC for, well... ACC)
Next you should check long coding of Module 16. For me worked value 0C 10 for DSG and 0C 20 for manual gearbox.
After each change turn ignition off, remove key and turn ignition on again in order to let modules adapt to itself. If this does not help then please provide autoscan and we will try other things.
CC is not working because it is more likely that it is programmed to stalk not to steering wheel. You need VCDS or OBD11 or other programming device to do correct coding and it will work like it should. Of course if You get correct parts. Also error about abs, steering wheel, wheel pressure, etc., will disapear after a short drive with steering wheel turns, it must adapt angle sensor, then alarms will disapear.I alway forgot to it the reply button
All above ! I can't try vcds now bc someone give me his unit ... Now i don't have it anymore... So i need to buy one so have to wait t'ill then .
