Hello,
New to this forum, I have just purchased a Cupra Formentor VZ 245 hybrid.
I admit that I am a little confused by the way the electrical management of my Cupra works.
Firstly, on the calculation of engine power.
Cupra Formentor 204HP: 150HP 1.4 engine + 116HP electric motor with 12.8KW battery = 204HP
Cupra Formentor 245HP: 150HP 1.4 engine + 116HP electric motor with 12.8KW battery = 245HP
How can we explain such a difference in calculating the total power with identical engines?
Concerning electricity consumption, the Cupra can travel 55 km (WLTP).
On a journey of 42km per day, cool driving mode, heating off, outside temperature 10°, after 40 km, I was at 0km range and at the end the petrol engine started with a reserve set to 0.
What is the average autonomy?
Some people say that to preserve the battery, you should not go below 20% and when recharging you should not exceed 80%.
The 12.8KW is the raw power but not the usable power as with all batteries.
To my knowledge, we cannot manage the maximum recharge.
If we put the reserve at 20%, the autonomy drops by around 10KM.
Also in automatic charging mode among the 3 modes (automatic, light or strong), the slowdown is sometimes too strong and a message informs me that I must release the accelerator pedal to respect the speed limit.
The car slows down too much requiring you to accelerate to restart it with greater electrical consumption.
How does automatic mode work?
I am in Comfort driving mode.
Can switching from full electric mode to hybrid mode and vice versa be done while driving?
I feel like all battery management settings are reset to defaults on every startup?
Is that the case ?
To program the charging time during off-peak hours (10:30 p.m.-6:00 a.m.), I use the “departure time” menu which I set to 7:00 a.m. departure time and Reduced rate. There are 2 options -Air conditioning or -Charging.
If I understood correctly, the departure time allows the car to be preconditioned.
By putting Air conditioning to OFF and Charge to ON, what happens?
This morning, I left at 7:00 a.m. the car started on electric and switched to hybrid without seeing it return to electric (full battery).
I deactivated the start time and was able to return to electric mode.
I would like to have opinions and give me advice on use to improve electric autonomy.
Also, what is the fuel consumption on the highway with the battery discharged?
I get a message telling me I need to do an update.
Should we do it with the gasoline engine running?
Is that the case ?
