Brweak pads OEM code help me!
Feb 2, 2024
17
TSI 2.0 190CV 4Drive
Can someone help me? I can't find the brake pads (anterior) for my car. On auto-doc they don't come out by inserting the model. Is there a complete online catalog of the codes for each Formentor spare part like there is for BMW?
I am attaching pictures of the brake pads, a link...somewhere must buy them...anything is welcome.
SuperV8
1,549
686
This OE number 5WA698151T is very new - and I can't see any aftermarket version yet.
5WA698151N is very similar with different shim and no wear indicator which may work for you? There are aftermarket versions available.
Feb 2, 2024
17
I've tried everything everywhere and it doesn't work, it seems like they don't exist. I no longer hope for special pads :-((
SuperV8
1,549
686
8 aftermarket suppliers in autodoc link to that OE number!
Why do you want new pads - are they worn out?
Feb 2, 2024
17
THANK YOU! I only put 5WA698151N without "OEN" :banghead2
are you so kind as to give me the code for the rear ones too?
Feb 2, 2024
17
No, but I don't want to go to the dealer when they are worn out. I also wanted to see if there were any "special" ones like the Ferodo Racing ones for example.
SuperV8
1,549
686
....ehm sorry...The OE number of the rear pads?
See my previous comment:
There are 4 options! If you share a photo of the rear pad it might help?
Feb 2, 2024
17
BAH!? same OEN codes and pads with different sizes, i go CRAZY!!. I am forced to remove the pad and measure it as I did with the front ones.
Very uncomfortable
dashnine
453
174
Warwick, UK
Apparently there is a new OEM part number out for the rear pads, to prevent pad stiction with a different pad material. Don't know what the part number is as the invoice went to Cupra Warranty.
SuperV8
1,549
686
Very uncomfortable
Just share a photo of the pad/caliper through your wheel and I might be able to identify.
SuperV8
1,549
686
looks like:
Rear pads: 5WA698451G
drag reduction springs: 5WA698269B
caliper spring: 5WA615269
272x10 Rear discs: 5Q0615601D
Your rear brakes are hardly worn -
