OBD Modifications
Dec 1, 2023
Hey,
the module arrived today. installation went well. I didn't disconnect the battery. Neither does the airbag. I simply left it plugged in and installed the module. module works perfectly. Thank you.
Reactions: witek_77
Dijon92
15
Installed a new steering wheel today and followed
Hi guys,
I did the steering wheel change and this is the complete guide, taken from here and improved. Now no errors in the gateway and Emergency assist is complete
- Obtain a capacitive steering wheel with travel assist button
- Switch on the ignition for power steering
- Turn wheel 90 degrees
- Release one side of the airbag unit with a flathead screwdriver
- Turn wheel 90 degrees, opposite direction
- Release the other side of the airbag unit with a flathead screwdriver
- Return steering wheel to neutral position
- Remove negative pole from battery and wait a few minutes
- Unplug airbag unit.
- Remove old steering wheel (M12 XZN tool required)
- Install new steering wheel (M12 XZN tool required) fix at 30nm + 90 degrees
- Install airbag unit
- Hook up battery
- Power on car, it may be necessary to restart the car again to reset errors.
- Coding with OBDeleven
- Select Driver Assistance A5
- Select Long coding
- Select KLR
- Set to Coded
- Select Point of intervention
- Set to Early
- Select HC Warn Intensity
- Set to Setting_over_menu
- Select HC variante
- Set to Variante_2
- Select Adaptive cruise control 13
- Select Capacitive_sterring_whell
- Set to Installed
- Select Travel Assist
- Set to Activated
- Select Gateway 19
- Select Adaptation
- Select Specified installation of sub-bus users
- Select Control module for sterring whell touch reconition
- Set to Yes
EMERGENCY BRAKE SYSTEM
- Select Module A5 (Driver Assistance)
- Select Long Coding
- Select Emengecy Assist
- Set To EA Variant 4
- Select Control Unit 09
- Select Adaptation
- Flashing
- Fahrerassistenz Blinkenfunktionen
- Set to Wechselblinken Warnblinken Bremsblinken
- Warnblinken durch Fahrerassistenz
- Set to Active
- Hupen durch Fahrerassistenz
- Set to Active
- Travel Assist
- Set to Active
- Innenlicht durch_Fahrerassistenz
- Set to Active
Alternative
- Select Adaptation
- Interior light general setting
- Set to active
Installed a new steering wheel today and followed The instructions but when I start the car I get like 10 errors. No way to get rid of them
witek_77
120
52
PL
You need to ride 500meters. Then turn off car. After that remove faults. Should be ok.
Dijon92
15
Yess just did that and works perfectly! Also with the module from ebay so no message anymore.
Next step heated steering wheel
Reactions: witek_77
Dijon92
15
@witek_77 do you know why my travel assist isn't blue while it's on? I have seen in video's that the lane turns blue. It stays gray for me.
Feb 22, 2022
97
47
Yes !
the coding is this:
control unit 03 brakes ,
long coding you move to the bytes, drawing 0101010101
you go to the bottom moving all the way to the right, count 6 going back to the left and you find an entry starting with A, mine was A2
Remove bit 01 and put in bit 02 - the entry becomes A4 .
Scroll to activate.
finished
the byte with the letter “A” followed by the number is in position 15 for me; can you confirm it is byte 15?
witek_77
120
52
PL
Su quale byte devo spostarmi e quale bit devo modificare per attivare il menu TCS, ESP ecc.?
Cupra formentor
Scroll to activate.
finished
Now my A4 is on byte 26. I dont remember on which was A2 earlier.
Reactions: simoammi
Dec 16, 2023
Lo más importante, ¿puede un volante con paletas para un coche manual? Quiero hacer esto para tener ayuda de viaje en mi sillón. Y la segunda pregunta. ¿vale la pena?
la referencia es 5FA959542
The seller tells me that he believes it is capacitive. But I would like to know your opinion, because it is not fr, it is x, and I don't know about the subject. thank you
witek_77
120
52
PL
Hmmm. I have xcelence capacitive 5FA419091EL. but yours also looks capacitive. has a cable and plugs for the KLR module.
Dec 16, 2023
Here I saw that it has a manual gearbox (in the cockpit you can see that it is in gear 6) and it has a capacitive steering wheel with paddles
Dec 18, 2023
Hello, I have a question, I have a Seat Leon 2023 with Lane assist, classic regulator and anti-collision front sensor. I coded the semblance of travel aid and it works very well. I have a Travel assist icon in my multimedia screen with the possibility of a Low-medium-eleve rule. But it is still active, I don't have buttons to disable it, I only have the button to disable the classic Lane assist. So to deactivate the "Travel assist" I must deactivate the Lane assist. I wanted to know if it was possible to have a button only to disable travel assistance and leave the classic Lane assist? Also, without a capacitive steering wheel it is still not possible to deactivate the message to get back behind the wheel?
Finally, with my configuration is it possible to activate the ACC? Thank you very much for your answers!
Leon xLux st etsi
26
Scotland
Congratulations on your modification !
could you give us the link to the seller of the steering wheel ?
I can’t seem to find one on eBay or maybe I’m using wrong terms for my search.
Fantastic discovery, I have done similar think to my last leon mk3.5 and fitted cupra steering with paddle shifters.
Is there any acces codes needed to do coding? Thanks in advance
Dec 18, 2023
mounted. Unfortunately, the percentages do not allow me to take the test today. the errors were cleared and nothing came back. We'll see.
@simoammi for me this module works perfectly. Yesterday I drove 30 km without touching the steering wheel. there were 4 red traffic lights and some traffic jam. the rest of the way about 90 km/h.
View attachment 39397 View attachment 39398
Hi! Do you think it will work for my car? I have a Léon 2023 without a capacitive steering wheel, I only have the Lane assist. Will it prevent me from haing the alert every 10 seconds? Thank you!
