The AZQ engine from my knowledge and experience does NOT have AWD. I solved this error by recoding some module. You have to find out which one exactly as i don't remember. I had these errors because someone ****** around and recoded an ECU i bought as a replacement.
My car still misfires and to this day has the MIL for the engine still on, compression tests are totally fine.
Search around the modules and recode them. Here's a
guide that might
help you.
Thanks for the link, its something that I was looking for. Guides, but only for
IBIZA 6L
I will try to disable AWD through that way - yeah,
Ibiza does not have AWD lol. But the weirdest part, is that, when I got the Vag cable, on my 1st check's I didn't have that error, they only appeared after. So, I can conclude that it was due to any output test or something, since I do not mess with coding. I'm trying to find, what triggered that, and enabled AWD.
So, lets go to your
problem, I will try to
help you, since I'm messing with my car sensor's, etc. Cleaning them all - since my car has a huge Fuel consumption - around 10/11 L/100Km. And when I am stopped, and run the car, the consumption goes to 40/50/60L / 100Km, even with a super slowly and carefully start on pedal.
- Did you check your spark plugs ? assure that you have the proper spark plugs and they are ok - try to proper clean them and the distance on the spark plug itself is OK.
- Check the Spark plug coils - 6L is known for Coil issues - to test that, just change their positions 1 by 1 (just remember to number them, to know and remember which is which), and see is the misfire cilinder on VCDS also change's - If so, is a Coil
problem, you need to get a new one.
- After checking this, you can go for the Fuel Rail. With a manual/video
Help, remove the Fuel Rail and clean the injectors - could be a faulty or clogged injector or even a fuel rail issue (so try to clean the fuel rail either) - there are cheap adaptor's to clean the injectors on aliexpress (1 by 1), you only need that, and a Spray cleaner. You also should replace the O-rings and injector filters - which are cheap material to get, and a "easy" task if you follow the rules.
Here's the process about the cleaning piece that you could buy on aliexpress or maybe on Ebay/Amazon:
Replacing the injectors filters (short version as example - you could check for a long further video to check all the process, but basically is this):
#shorts #cars #carguy #mechanic #diy #fix #learn #lamboDifficulty: 4/10
www.youtube.com
You can also to clean the throttle body, EGR, etc, but I think that does not
help with a misfire in the cylinder. I'm not a mechanic, but I perform some DIY cleaning on my system, so if you need
help, let me know. But honestly, I think that the Injection system cleaning could solve your
problem, if not, could be a cylinder
problem or something - that part, only a mechanic/professional will could tell.
