Interesting fault smokes when eco mode switches off help please. Updated.šŸ™
Jason2023
46
15
Hi All just joined and first thread. I have a Leon fr 1.4 tsi 150 2016 mk3, put simply it switches to 2 cylinder mode fine but after a say 5 mins in this mode when switching back to 4 cylinders a noticeable puff of smoke is seen, but if switching back after running in 2 cylinder for a short time nothing. It doesnā€™t do this accelerating with 4 cylinders even after 5 min delay. Any ideas please?
mty12345
3,907
538
bristol
It's just oil accumulating in the 2 unused cylinders, that's being burnt off when they fire back up. Not a fault, just a consequence of what is a silly design IMO.
It was probably another case of it allowing VW to claim better emissions under some obscure test conditions, but in the real world it does nothing. I can't imagine those big puffs of oil do the life of you catalytic convertor any favours either. If you have an option to keep it in 4 cylinder mode all the time, i would definitely recommend doing that.
Reactions: Jason2023
Jason2023
46
15
Thank you for your reply, had a suspicion along those lines! I have considered running 4 cylinders but reading a thread on here it triggers others fault warnings. Have you seen any methods of turning off eco mode?
mty12345
3,907
538
bristol
No worries mate, welcome to the forum btw too.
If continual 4 cylinder is known to cause other issues, then i'd just stick with letting it do what it wants to do. I haven't got any first hand experience of these models, I just knew the answer because i'm an engine nerd lol. Maybe just boot the throttle here and there if you've been in 2 cylinder mode for an extended period of time, just so you're not putting loads of unburnt oil into your cat at once. If it's enough oil that you can see it, then IMO it will definitely shorten the life span of your cat in the long term.
Edit: If you're new to the car then definietly keep a good check on the oil level. Eco engines and engines with cylinder deactivation often use more oil than more traditional designs. That's the main reason i said i don't think they are much benefit in the real world, as the slighty higher MPG is often offset by the fact they burn more oil.
Jason2023
46
15
Oil used is about 1 litre per 1200 miles. Thanks for the replies, had the car since 23,000 miles now running just as good at 91,000.
SteveGSXR600K1
589
193
As you've driven the car for 68,000 miles, is this puff of smoke a new thing or has it always done it?
Jason2023
46
15
I noticed it from about 40!000. But could have always been there you have to look at the right time. I wish it was easy to turn the eco mode offā€¦.
Seriously?
1,324
904
Obviously there is a natural variation between engines, but our 2018 1.4 EcoTSi has only ever needed minimal top-ups between oil changes.
martin j.
1,997
894
Fife
Never noticed this on ours but now Iā€™ll check, but it probably never gets into 2 cyl modes for 5 minutes at a time anyway.
Jason2023
46
15
Interesting thanks spoke to garage they seem to think oil usage isnā€™t outrageous and can varyā€¦
Jason2023
46
15
yeah you have to let it sit on 2 cylinders for a couple of mins at least, Accelerate or put a load like a hill you may see something (hopefully you donā€™t).
SuperV8
1,549
686
Final update on this, the engine gave up in cylinder 3 Totally went. ā˜¹ļø many pounds spent a donor engine new clutch etc . Now running like a dreamā€¦..šŸ™„
Glad its sorted but that's crap! - curious; what were the symptoms when it went? did the smoking get worse?
Jason2023
46
15
Thanksā€¦ the car started to misfire a little, not a huge amount. Then one drive home misfired big time limped home. Couldnt get coil packs out to investigate welded on. So local garage helped out. When took spark plug out of cylinder 3 it was melted and no compression what so everā€¦.
Reactions: SuperV8
MA1601
46
15
Sorry to hear that. Wonder what failed. Only ever read good things about the 1.4 ecotsi engines donā€™t think Iā€™ve heard of a failure until now..
Walone
1,634
462
Near Heathrow
I'm a bit concerned that there was no compression at all, wondering if the 'ECO' cam actuators had jammed the valves open?
Jason2023
46
15
That's terrible. Do you know what failed?
It was a tough choice.. we know the cylinder had no compression after it failed and in the past the plug on 3 on got oily regularly so changed an injector which seemed to cure the wet/contaminated plug. Back then we did a compression test and all cylinders were fine. So knowing there was a bit of history! So the question was did I pay to find out what it was then have to pay repair cost on a 99k engine or swap it for a newer one with on 61k on it whilst changing everything I could while the engine was out. So I decided not look back and just swap it out.
time will tell but so far looking good! Did 4 hour motorway round trip it worked well. But have to admit listening to every noise atm. šŸ˜…
Reactions: Mr Pig and Walone
Jason2023
46
15
Thanks.. I know originally went to Seat many miles back they didnt have any idea. It is unusual as you said mostly only hear good things on the 1.4 150 act.
