white smoke on cold start 1.9 tdi
Leon1PSilver
16
Hey guys, i have the following problem which i cant find and fix for it. -- 1.9 BLS
On first start in the morning when the car wasnt driven for a while a short white smoke comes out like a puff and its instantly gone.While driving there is 0 smoke, on full throtle neither on start ups when car is driven so only when the car been standing parked for a while on first start white smoke. The car doesnt waste oil/coolant no errors on VCDS.I changed glow plugs, injector seals new oil dpf/turbo/egr are perfect no boost issues or anything at all car drives like a dream.
Any ideas? thanks
R3k1355
1,854
271
Yorkshire
Could be a slight leak or dribble from the injectors when the car is off? If it's not using oil or coolant, I wouldn't worry.
How easily does it start from cold? If it takes a couple extra turns to get going, that could be causing the white smoke.
Leon1PSilver
16
Starts easy, very smooth and no shake
