MIB2 map update question
LeylandVCDS
457
280
Leyland, Lancashire
Wondering if anyone can help here.......
Got a 19 plate Leon with an MIB2, which uses an AS marked SD card for the maps.
I am wanting to update the maps via the portal.
I am NOT wanting to wipe the existing, working AS card until I know I have another working map card, and have tried using an older AT marked SD card that was surplus to my older Leon, which had an MIB1 unit. The card worked fine in that car. It is a genuine SEAT SD card, but the new maps downloaded from the portal onto it are not recognised by the MIB2. I thought that as long as the card was a genuine SEAT card, whether marked as AS or AT, the update would be OK, but can't get it to work. I assumed the difference was in the content on the card.
Do I specifically need to use another AS marked card for the update, or am I doing something wrong in the preparation of the AT card?
To clarify, the old MIB1 AT map has been totally formatted off the old AT marked card, and the correct AS map downloaded from the portal onto that card.
Many thanks for reading, hopefully someone can point me in the right direction.
Tell
Yes the mib1 card should work fine in a mib2. Assuming its large enough. Not sure of the size of mib1 cards. There is a CID signature on it which is interchangeable across the VAG brand for mib1 and mib2. You do need the "workaround" (the term the Seat board gave it). On Seat mib2 standard which is what yours is the first card put in it teethers the unit to the serial release of the card. The good news is copying that overall.nds file to a higher release over writing the releases overall.nds file makes the update work with the unit, aka the workaround.
There is a resource which details this and a discussion thread.
Always back up the card before starting this process
although you can get the system working again if you loose the overall.nds file by deleting it (the mistake) before copying the original, that is detailed. People do it by ignoring the Seat site that says it doesn't apply to UK sold cars, follow the website instruction (delete the contents) and don't have a mapping system that works after this. The year dot overall.nds file digs you out of this hole. Link provided.
Generally always use the VW map file links they are more up-to-date. Seat and Skoda drag their feet on posting up those. In the community we post up the direct link to make it easy.
Resource:
Discussion thrrad:
LeylandVCDS
457
280
Leyland, Lancashire
UPDATE: no matter what I tried, the AT card would not work in the MIB2.
Took the plunge, took a backup of the original card out of this car, and downloaded the latest maps from the portal. Swapped the OVERALL.NDS file from the original mapping that was on the card, and everything now working with the latest maps.
Big shoutout and thanks to @Tell
Thanks for all your help and time, much appreciated
Reactions: Tell
Dec 21, 2024
Hi.
First, let me thank you for sharing your experience.
I was searching for the OVERALL.NDS file in the the original SDCARD and found many OVERALL.NDS files in different folders.
Should I replace all the OVERALL.NDS files or a specific one?
Thanks for the help in advance.
Reactions: LeylandVCDS
Tell
No it's here:
Steps:
  1. Download the latest standard MIB2 maps
  2. on the infotainment go to settings, safely remove, sd1 card
  3. remove sd1 card from glove box slot
  4. long press on the on / off to reboot it a couple of times
  5. insert sd card in to computer
  6. copy and paste all contents to a directory on your computer
  7. Format the SD card keep it as fat32 and leave format settings as default in file explorer (don't forget to push the card lock mechanism to off) (ditto in a MAC or delete all from the SD card)
  8. Copy the new downloaded map version to the SD card (after unzipping it)
  9. Replace /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card
  10. eject the sd card (on a MAC run CleanMyDrive on the SD card - then eject)
  11. Inserted the card into the card 1 slot in glove box whilst infotainment is off
  12. power on and go to navigation
Number 9.
If you have lost your original overall.nds file this one will do
It's the year dot of the file. Use a feature of mapcare this means it will fix all release of the map card thar the infotainment unit is married up to.
Basically the car is carried to the map release that is put into the unit. Moving that file it still thinks it's married to the original file. That file doesn't need to be original even if you use the year dot release. That is used to fix updates where people get carried away and don't take a copy of the file for the workaround.
You do need to use a VAG card thou, it's reads the CID. It's how they keep a revenue stream going.
No it's here:
Steps:
Number 9.
Hi Tell.
Thanks for the very fast reply.
I just replaced the "/maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card" as mentioned.
Thank you very much.
LeylandVCDS
457
280
Leyland, Lancashire
Hi.
@Tell has just beaten me to it. Just this one needed!
"maps/EEC/EEC_WLD/OVERALL.NDS"
Reactions: Nuno
