The motor needs to have a specific sensor in it to get it to steer. They don't fit them in all so if you do the mod it drifts with repeated use. I show the
Obdeleven code on the normal
Ateca pinned thread.
Now the OZ Don published a way of testing weather you have the correct mirror equipment, I called it the "Don test".
Follow the link:
Hi, I recently got
OBD11 pro and was wondering what's the best option you activated with
obd11 and can't drive without it on your
seat ateca?
www.seatcupra.net
My standard
Ateca failed the test. Basically Seat stopped fitting these motors where they were sold without the feature. Either way you can read the positioning data and you know you have correct motor fitted, thanks to DV52 (Don).
I think you will find you are out of luck. Mine didn't have the positioning motor fitted that gives the extra wiggle to get it back as I understand it (servo). Over a period of use if you do the mod on one that's not kitted out with the correct motor they drift. You just have to reset after a period (10x of reversing or so).
It was a known issue with these
Ateca sold without the mirror drop down were not designed to drop the mirror with precision and return. I only coded mine for the hell of it. If it's sold without mirror drop down it's unlikely to have the correct motor fitted. This is where Australia Don comes in since out there cars were arriving some some without the correct motor, some on left and right together. Hence his test.
I got 360 / Top View which does for grid line parking. Saves messing about. Got the garage white line sprayed as well. Buy the paint from Screwfix. Make a mould and bobs your uncle.
I put the
Obdeleven coding for mirror dip on this thread. People like it if they come from a car with it but even if you had the correct motor I don't reckon the
Ateca mirror shape and body height is useful to give you a good view down. It's worth a try. Some people find it useful although it drifts on the 2017 models atleast.
This thread covers the use of the
OBDeleven tool with worked, tested results on the
Ateca 2016 - 2019 models. Check
Obdeleven website for news on programming the new 2020 models on progress of this "The programming temporarily is not supported on models that are manufactured from 2020 and have...
www.seatcupra.net
