Hello, so I am new to forums and I have looked to see if this has been discussed before, but I can find anything.
So i have a hunting idle only on cold starts, and lately I have noticed my mpg has dropped from around 23-25mpg around town to 10-14mpg.
Since owning the car I have had r tech stage 1 with injector clean and intake valves walnut blasted plus new pcv and dv. Timing belt and cam chain replacement. New coolant temp sensor. New pre cat o2 sensor. New maf sensor.
I am wondering if I might have a small vacuum leak that may have gotten worse over time. What would be the most common vacuum leak? Also I have a obd eleven scan tool that is showing no codes.
Thanks for your help in advance.
