Replied to you on the Polo forum but didn’t realise you were here too
Hey thanks for getting back to me, appreciate it.
Hmm not sure then, I’ve had the car around 6 months now and experienced relatively underwelming/poor MPG from day one. Should’ve just returned but thought I’d see it through thinking it’s because I’ve got a new car that may have been sat undriven for months, just need some time to break in.
I’ve calculated manually here and there not consistently admittedly, didn’t seem too different to what the computer was reading. But started to track again tank to tank using an app last week. So will have to wait and see.
I’ve tried different fuel brands Tesco Momentum, Supermarket, Costco etc. Doesn’t seem to much in it for difference tbh.
Probably getting on average 320ish miles from a full tank and according to the trip computer that I’ve reset previously, my average over last 2000miles is about 28MPg.
I’ve seen people with Cupras get better.
My journeys have been a mixture of short and long journeys, but I do like to take my car down the motorway every so often when I’m mainly doing short. To give it a run and to see what I can squeeze out of it
Nobody else drives my car just me
Tyres have been the same since I bought it maybe something I should look into not sure of the brand will check tomorrow
I know typically fuel economy worsens in winter but can’t figure out why mines so bad when I check owner groups and people with the same model easily seeing 40+ and I’m struggling to get low 30s even on a long run.
Thought a major service might have done the trick but nothings changed, car does seem a bit smoother but fuel wise nah
What’s the best way to force a regen? Just so I can at least rule that out.
Took from screenshots last week from
OBDeleven live data on engine block, after seeing this thread, not sure if it means much. Not exactly sure what I’m looking for and was taken shortly after starting car hadn’t driven it.
Been to a Main dealer about this fuel economy issue but seems they won’t investigate if they don’t see any fault codes which is annoying.
Definitely something wrong here what it is I don’t know.
also popped into the dealer today and apparently my fuel consumption again is normal. As my car is supposed to get 40MPG average.
So me getting sub 30 is okay.
