East Yorkshire Retrofits
Forum Sponsor
Yes, but it isn't cheapHi , does anyone know that if is possible to activate full link app ?
I did not order it on the ordering of the car and would like to activate it now.
Thnks
Thnks
You can't DIY, we can do it for you if you have the necessary equipment for us to connect and workHow can I do it ?
Thats ok , just let me know what i need .You can't DIY, we can do it for you if you have the necessary equipment for us to connect and work
I don’t think it works on MIB3 to install full link app.Genuine VAS6154/6154A
On the OP and your last question you would be able to do the same using VCDS as OBDEleven Pro. The later costs more. Doubt other "One click" OBD dongles would do it. Pro gives you the same level of "programming" as VCDS, one click dongles try to make it easy for users to do one click but obviously they have to target what that function is. Really like a spreadsheet macro of commands. They are not good to use since you have no command over them. Saying that if you saw a dongle advertised that claimed to do it, it might subject to whether it's implemented well.
0870 is the latest software. Worlds apart from your current one
Do they wait for an update or ask the dealer or Obdeleven Pro it. If it's not a bug the firmware won't be updated will it like mib2 firmware. Will be static.0836 is the latest software. Worlds apart from your current one
Wireless is fairly easy on that unit
Is obdeleven doing software updates now? Or still just telling people there's updates available for modules that if they attempt it'll kill the moduleDo they wait for an update or ask the dealer or Obdeleven Pro it. If it's not a bug the firmware won't be updated will it like mib2 firmware. Will be static.
On the first it just provides info that other people have newer firmware not that it will do it. I ignore that / note it. The amusing one was when it said there was newer firmware to mib2 high than 1447. It started the egg hunt off. The guys behind the AIO software use a backdoor to duck the SLA1 signature check and manufacture the checksums as well so it gets read in ship shape. All clever stuff which meant they could slap their own release code in what had manufactured. Well someone had. The use of Obdeleven had seen that code and started the egg hunt off. Now they keep the release code to 1447 but add Gracenote updates beyond the final release of 1447 plus the lifelong FeCs in the package. Moral there somewhere.Is obdeleven doing software updates now? Or still just telling people there's updates available for modules that if they attempt it'll kill the module
0836 fixes the weird on screen artifacts when using wireless carplay, amongst other issues. It's night and day compared to his existing software
Only seems to run OTA when there's an active seat/Cupra connect subscription however some have had them run OTA without a subscription. I usually end up performing it locally
All correct up to "the ability to create a script of my own". For that you need a license above the Pro. Making your own scripts is the "Ultimate" license. The OCA builder referred in the link is in the Ultimate.So to get this straight, cause I'm kinda newbie here....
one click apps are pre-defined scripts that run several commands?
pro version let u see all available commands and run them one by one, with the ability to create a script of my own?
Nah unless @East Yorkshire Retrofits knows a way. If it's a bug an over the air one from Seat are known. They have done those with some Mib3s. Others they call in. If its not deemed to be a bug it wont get fixed for free.Oh ok, there's the ultimate one as well right
Anyway the pro is a must in order to enable AA wireless.
About the other discussion u had with East Yorkshire Retrofits, is there a way to update the software on my own?
Thinking about it, do you still need to code to enable the screen. I expect you do. So it's an upgrade to more reliable firmware but still you need to code since the behaviour is defined by the long string of the unit which won't change in the firmware upgrade.
I'm not entirely sure what you mean. Once it's updated, it's updatedThinking about it, do you still need to code to enable the screen. I expect you do. So it's an upgrade to more reliable firmware but still you need to code since the behaviour is defined by the long string of the unit which won't change in the firmware upgrade.
