I decided to carry out some additional styling to my Formentor. I have a new front splitter, rear diffuser, rear spoiler extension and a metal Cupra driver's footrest. All the exterior parts used are in gloss black, although matt (textured) and carbon fibre finishes are available. The front splitter is the V1 design and there are two other designs available. The rear diffuser is removeable, so if you have a tow bar fitted you can still use it and the virtual pedal sill works just fine. The Cupra metal footrest was purchased from eBay and I think it just finishes off the driver footwell nicely. The only issue I had was with the rear diffuser as this came with no fitting instructions and has plastic pop clips to mount it. I had to work out that the drill size required was a 7.5mm. Apart from that it was all very quick and easy to fit. Also, if you don't have a tow bar the rear diffuser covers the rather large gapping hole under the rear of the car. The exterior styling parts were from Maxton Designs.
