Door condensation
Big A
244
156
Do any of you have problems with condensation on the inside of your back doors? Picked up the wife from work and went into the back seat to get her bag and noticed the inside of the door was all condensation. Tried the other side and it was the same.
It is 10 degrees here and dry, so wouldn’t have thought there would be any condensation, and the car hasn’t been near any water either.
Tormentor
199
102
View attachment 30452 View attachment 30453
Mine is similar but not quite so bad.
Big A
244
156
That is the first time I’ve noticed it since I got it in December. My car is going into the dealer in a couple of weeks for update, rattles and couple of other things, so looks like this might be another thing to add to the list. It’s as if the weather seals on the doors aren’t doing their job properly.
Tormentor
199
102
I put it down to condensation as opposed to water ingress.
Reactions: Big A
Napmasterflash
258
155
Mine has this condensation also. Would be interested to hear the cause of this.
Sent from my Pixel 5 using Tapatalk
Big A
244
156
I’ve dried it off, and will keep an eye on it to see if it returns.
Good to know that it’s not just mine. I’ll see what they say when it goes in to the dealer in a couple of weeks.
Cupradev
169
100
Same on mine. It’s the outside of the door seals so I’ve not really thought too much about it, and most likely won’t. 😬
Had my VZ2 310 9 months now and absolutely love it. I still find myself looking back at it when I walk away, incredible design.
Reactions: Bear
oldgitdave
508
241
UK
Never noticed this on mine so far but thanks for the heads up, I'll definitely keep an eye out for this and will update if I see anything. I always clean the door shuts after washing and there's bound to be a bit of water outside of the seals. Just a suggestion do you guys keep the aircon on at all times? I keep mine set at 19-21C on auto which will keep the humidity down of course.
barqqsanu
59
23
I also clean and dry it after washing, but I noticed the problem after a heavy rain. And not only once, but multiple times....
Nige Mx
Yes, mine is the same, photo shows with a small area around the door latch receiver, it seems to be there each morning even though I do dry it off. I don't think it is harmful but will mention it when I take it in for a service.
