Rims for Formentor VZ 228kw + Brembo
ferretz
28
14
After checking with the garage, they are also not confident about ET30 so I will give up on these and will stick to the ET35-40 range as suggested by @Jaco2k
The rims can be mounted but registration is required (meaning that you need to present the vehicle afterward for homologation and potentially they may requires a wider body kit) so I'll stick to wheels for which no registration / presentation is required after mounting them.
That reduces the choice even more.
New candidates (no registration required) are:
AUTEC WIZARD GUNMETAL MATT IN 19 INCH​
FA 8.00x19 ET 35 - RA 8.00x19 ET 35
AUTEC LAMERA MATT BLACK POLISHED IN 19 INCH​
FA 8.00x19 ET 38 - RA 8.00x19 ET 38
OZ RACING FORMULA HLT GRIGIO CORSA IN 19 INCH​
FA 8.50x19 ET 38 - RA 8.50x19 ET 38
OZ RACING HYPER GT STAR GRAPHITE IN 19 INCH​
Autec are afforable and unfortunately the OZ's are very expensive so despite I prefer them, I'm not sure I want to cry when I will touch a sidewalk :)
OZ certificates cannot be directly downloaded so I'm contacting them to ensure all is good without a special mention.
Jaco2k
AWD FTW
Mar 11, 2018
1,042
638
Tampere, Finland
www.youtube.com
Do you know this site? You may get some extra ideas:
ferretz
28
14
No I didn't and it's precisely what I was looking for, they also offer the same page for 19' (still not sure if I'll go for 20 or remain in 19):
https://www.cupracer-hilfe.de/19zoll
So thank you again, I'll have a look.
Some are actually in ET30 with this A01 code (registration required) but yes that really helps and may suggest me brands that I didn't know about.
ferretz
28
14
I finally went for the safe option: Borbet Y 8x19 ET37
It was at the end the only model for which I was 100% sure that they would fit even with the Brembo brakes and be approved.
I did not want to take the risk of having not approved wheels or any potential issue with the brake calipers.
There's actually well enough space, I would say even more distance between the calipers and the wheels than with the original Cupra wheels.
Reactions: T8COH and BigJase88
