Hi guys, I own a VW golf 1.6 TDI 110hp (year 2015 and 70000 miles). Shortly, I have the same issue as yours, or worse, and I'd be happy to contribute (for what's possible). Using the VAG DPF app since a year now, early on I spotted the car was regenerating every 30 km (20 miles), and consuming 1L oil engine every 1000km (0.42 gallons every 1000 miles). Short story short, I had bought the car as second hand so I and the car dealer repaired the car. Our hypotesis was that the engine oil was making the DPF filter dirty, triggering regenerations which by turn would dilute the oil with diesel, and so the oil would get though the clamps. We opened the entire engine. We found ovaal cylinders and had to rectify the whole engine.
Problem is, the oil
problem was solved, the DPF regeneration not. I keep having constant regens every 20 miles and the app has the same behaviour as yours, ramping up the soot mass calc. from low % to 100% in seconds. Before rectifying the engine I also changed a DPF sensor (G450), which wasn't giving any faults but the car electrician said it was reading wrong numbers. Of course it didn't solve the
problem. Maybe also the one he installed isn't good? What to say, I'm now getting along with this issue, as the car regenerates very very often, almost every time I use it ( and I use it mainly on highway).
What's left to try in my opinion is:
- replace both g450 sensors with new ones or second hand ones from a junkyard;
- worse, maybe it is the ECU which is giving faulty values? Should it be remapped or replaced? $$$
Any
help is more than welcome if you find a solution.
@Brian Gordon-Stables @Skilledmilk @alextz
