You cant program with the Carista which means it's app only. It does have it's fans but will never do what
Obdeleven can do. The "programming" in
Obdeleven 99% of the time is toggling boxes as the examples above on the
Formentor. It's only when the byte editor doesn't have the text shown do you need to bother about bit and bytes (0-1) toggle top right of the
Obdeleven screen toggles between the parsed text screen and the stuff that looks more machine code.
You do need the annual Pro licence thou for
Obdeleven. If you already have the Pro unit from before they put in the annual license you are covered, licence for life, if a new user you need to get the Pro license unless you use the
Obdeleven apps with the micropayment method, same as Carista.
To get the
Obdeleven you can order it from Amazon online but pick the Prime UK seller with next day delivery since its being held in the UK warehouse then buy the Pro license from the
Obdeleven site.
@Agnes.Surrey got herself up and running on the same day, with an Amazon same day delivery service, bit quicker than waiting 6 weeks for it to arrive from East Europe.
