Adding hydraulic bonnet struts to the Formentor
EuKiwi
196
115
Bavaria, Germany
Hey all,
Just thought I'd let you know that you can add these very easily to the Formentor, as the threaded fitment is there and ready, and covered by a sticker for the mount. Just simply buy this set:
And then follow the very easy guide as per this page (in German, but the images are enough). Very easy - took me literally less than 5 minutes:
Size 12 (lower mount) and size 13 (upper mount) ring spanners needed, and that's it.
Cupradev
169
100
Hey all,
Nice work. Looks great. I take it all the clearances are ok once the bonnet is shut?
fpdoc0697
48
18
Very good idea. I’m disappointed it doesn’t have them as it’s a nice premium addition that I have as standard on my BMW. Thanks
EuKiwi
196
115
Bavaria, Germany
The fact it even has the threaded hole there ready for the mounting nug just shows that it's a brand engineering exercise - even the VWs don't have them etc. and that's reserved for Audis and the like :)
Reactions: Boxhead_31
EuKiwi
196
115
Bavaria, Germany
Yes, no problems in the slightest. It's clear from the fact there's the threaded hole there for the nug covered by a sticker that it was always designed to have them, but was decided against late in the process. Can't have a SEAT/Cupra with them if VWs don't have them after all ;)
Reactions: Cupradev
AndyCupra93
296
127
It’s an odd backwards step, my 7 GTD and 7.5 GTI had gas struts but they obviously decided to save a few quid on the latest VW range.
EuKiwi
196
115
Bavaria, Germany
Agreed - and the interior quality of VWs has taken a big backward step, even some lower-tier Audis, with rear door trims no longer having soft-touch materials etc. whereas they used to previously. It's all cost-savings to try and recover from the massive Dieselgate fines.
EuKiwi
196
115
Bavaria, Germany
Ordered mine today, will post photos of assembly … surprised they weren’t standard option
Yeah definitely penny-pinching - but there's a lot of that now in the VW group due to the huge fines they were hit with. They save quite a bit of money actually for example with the removal of physical climate controls, moving them into a touch strip on the main display assembly and putting the climate controls on the main screen.
EuKiwi
196
115
Bavaria, Germany
As promised, a few pictures. Sorry, lighting wasn't brilliant as it was in the underground car park.
EuKiwi
196
115
Bavaria, Germany
Knowing my luck I would forget to take them off at the end if the lease and get charged for it
I spoke to VW financial services and they said no problems, as it's a reversible addition, not a change or modification to the vehicle or anything that increases wear on components etc.
Reactions: Yaz2010
Deleted member 131219
My only complaint is that they're a bit TOO strong, ie. quite a bit of lift needed to get the bonnet up, and then have to be careful when closing it too as they're a bit... enthusiastic :D
Still going to be an improvement on the prop. I haven’t had to prop up my car bonnet since 1998!
Reactions: EuKiwi
Agnes.Surrey
772
421
Surrey
I have one in Abarth (and real handbrake too), so was not shocked ;-) I would buy the struts, but to be honest, how often am I going to open the bonnet during 2 years lease? To top up windscreen fluid every few months? I assume, car will tell me if I need to top up engine oil or is it manual check too?
I’m old school, not trusting of on board check systems. :)
Reactions: EuKiwi
