400 HP - 600 HP UPGRADE Turbocharger LM440 IS38 LM500 LM575 Hybrid
Mar 30, 2020
13
@CupraRacer what ever happened with the development of the LM500 IS20? It seems like it was never released. Was the compressor wheel too large, and the TD05 turbine wheel too small to efficiently spin a compressor wheel of that size within IS20 housings? Judging by pictures alone, I have a TD05 based IS20 hybrid with LM500 sized compressor wheel and am wondering what type of performance I should expect from these wheels with MHI rotating assembly in IS20 housings. Thank you.
CupraRacer
47
37
LM has developed LM500 TRACK in IS38 housing with quick response of little IS20 - Nearly all get it. Consequently there is zero need of an LM500 IS20.
Fer16v
65
18
Spain
Dear @CupraRacer i beg for your opinion. Will i need HPFP & LPFP (when upgrading to LM500 Gen2) if i go the "soft" tune way (around 460-475cv) with this turbocharger??? High flow Injectors will be necesary too?
All the hardware is just installed. Only HJS 200cel DP is still left, but waiting to install (and deleting GPF). Mods are Remus cat-back, Wagner IC, Forge carbon full intake, MST inlet + muffler, GFB DV+, NGK91006, BAR-TEK black Ignition coils...
My goals are not to install high pressure pumps due to consumption, reliability and smooth drive, so i think 460-475cv is a logical point to not trespass. I know LM440 would be a phenomenal option, but my local tuner claims MUCH difficulty to achieve more than 430-440hp with the lm440...
A last question. In terms of rpm's turbo spool. Is it LM500 slower (or at higher rpms) over LM440???
Regards!!!
Cupi
47
Hi, you can install LM440 IS38 (even better spool) for 470 HP when giving it 1.9 bar boost pressure.
The LM500 Gen.2 is, of course, the greatest option. You can drive it also with 430 HP very softly because spool is great and early.
You do not need HPFP Upgrade (Autotech) because 7R injectors are enough. Lots of tuners can do nice software that your car consumes less when driving normal even if your 2.0 TSI gen.3 has got 480 HP - consuming just 8 litrtes on average - nice tune.
Fer16v
65
18
Spain
Sorry. I didnt say. My car is a 300 MY'20 GPF model. Are there any noticiable differences in terms of performance with this turbo set up vs pre GPF (Dual Port injection) models???
Cupi
47
The same performance...
You Cupra 300 has also got the stronger OEM pistons than the older Cupra/Golf 7R built before 06/2018
Cupi
47
LM500 V2 Gen2 Turbolader Upgrade Turbocharger Upgradelader Stage 3 Seat Leon Cupra 5F MK3.jpg 20200522_205642.jpg LM IS38 Upgrade Turbolader Golf 7R Audi S3 8V 8V.jpg 20200522_204742.jpg LM500V2_Upgrade Turbo.jpg LM500 V2 2018.jpg
sh5a5100
26
Hello there i have the same setup my cupra 2017 facelift with pnp575 forged engine with full setup
Stm engine stm gear i dont do this result as u post
Im looking for mr-chiptech files how can i get them or sho can help me to find a dealer to tune my car im from israel can u help me.
thanks
Cupi
47
Hi Guys, I have just installed the IS38 LM440 forged upgrade turbocharger - breathtaking driveability
Cupi
47
Hi Guys,
Here the new LM440 world record - received yesterday. For tunes ask Stertman, MR, MRC, Revo or the local tuner you trust. I do not provide any software because it is not my job:
Cupi
47
thanks
Hi MR does not send his software internationally - only when showing up at his local workshop - that is the only way. Stertman is also one of the best tuners worldwide...
Cupi
47
SPOOL-BOOST test of LM440 IS38 built since 2018:
6. + 5. Gear
2400 rpm = 1.26 bar (18 PSI)
2500 rpm = 1.62 bar (23 PSI)
2700 rpm = 1.97 bar (28 PSI)
