Reverse Light
Davesimmons269
53
20
Hi,
I have the Check rear left reverse light warning, the light isn't working so was thinking of buying this LED light
Is this correct and would this work? I currently have a 2020 FR.
TIA
Reactions: ryc1
Seriously?
1,433
1,029
A W16W is the correct fitting, but if the reverse light is monitored by CANbus then you need a CANbus bulb or it will more than likely throw an error message.
RoadRunnerRik
13
11
You can also change the light bulb settings with VCDS to LED if you get a light bulb error after the replacement.
carl^
30
19
Would this be a UK MOT failure same as replacing a headlight with a non-E marked aftermarket bulb? (assuming the tester is following the regs to the letter)
Davesimmons269
53
20
Thanks for the replies, i think i will just get a like for like. What is the best place to get them from and which specific bulb is it please?
