FR key cover
A.k
50
Just bought and installed the key cover.
Decent bit of kit
Picked up from local dealer
robby71
653
91
Yorkshire, UK
Aren't they silly money? you can get cheap versions on aliexpress if you're prepared to wait weeks for delivery
You just need the chrome end piece to finish it off
A.k
50
£23.40 link above. Collected from a local dealer.
Only buy genuine Seat accessories.
Messed it up a little as when peeling off plastic it peeled the sticker bit instead. Can see little lift on one edge.
Seat do the chrome piece?
emilyjane2910
54
32
West Midlands
It’s only a sticker?! 😅 thought it was a replacement case at first. I like the thought of changing the look of the key but the key is already bulky enough as it is without adding to it IMO
robby71
653
91
Yorkshire, UK
A.k
50
A.k
50
robby71
653
91
Yorkshire, UK
Found a chrome one but need to take the FR cover off to access FFS.
Oh well
They do different versions - plain chrome, GTi, GTD, R
I've fitted a few to previous VWs (pull back off fob then use a torx driver to remove screw the slide piece out and fit new) - the last VW i had was a 2019 T-Cross and the chrome was slightly different fitment so i had to use a dremmel to "modify" it to fit - weird?
A.k
50
Might do the spare key but probably just a waste of money. Would of done main key before fitting FR cover.
A.k
50
I purchased a different design: https://www.caraccessoriesplus.co.uk/product/seat-ibiza-2018-onwards-key-cover-speed/E6F0087013C
It certainly is overpriced even at £20.70 Don't think I'll bother with the chrome!
Not too bad the price. As it come with a alcohol wipe, 3m adhesive promoter wipe which makes the key tacky. Then you peel off film from the 3m pads and apply each section. I suppose a cheap version would be £5+. But might not fit right, lose its adhesive properties and design wear off fast.
Only time would tell if the genuine part lasts long.
A.k
50
€11+
No idea why it's £20+ over here.
Like the ice scraper is £20 on eBay. Yet £9 at dealership.
A.k
50
Chrome piece arrived, But i've damages the torx screw in key lol
oh well. will ask dealer to try for me on next visit
robby71
653
91
Yorkshire, UK
The black screw in the fob is very easy to round off - i did that and ended up using a very small precission flat screwdriver to coax it out.
The new screw is a bit better but you need a torx to get it in fully
SRGTD
2,560
1,405
A T6 or T7 Torx screwdriver bit should fit.
robby71
653
91
Yorkshire, UK
My chrome piece arrived today - same problem as i had with the T-Cross - it doesn't fit without modifying.
When you try to slot it in place it wont slide far enough so a bit needs cutting off (i used a dremmel) - you'll see which part but i've attached a pic showing the part - hope this helps :)
New Vs old
Yellow section needs removing
You're left with this
It now fits :)
