Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I bought complete strut top kits from TPS.
I think the oe ones are made from a stronger compound rubber as the cupras are a sportier car.
Id go oe if i were you.
You may buy some off Ebay etc or aftermarket that'll fit but you wouldn't be sure of the rubber quality/compound.
Think the kit is new bush, top bearing, nut n washer.
Was about £100 for the 2 kits if memory serves.
I'm not sure - is this a tie?
Hard to say. They both look the same
A definate hidden horror though.
To be honest it looked better than I was expecting and the bearing was fine.
Front ARB bushes likely won't come out without snapping the ARB at that age. At least that's what the garage told me last month because mine's knackered! They recommended I get an H&R one and worth getting the rear as well, so just trying to find the £360![]()
I know what you mean but it hasn't got the weight of the car pushing down on it now.
Take another 5-8mm off for that.
As if, its just 2 crusty clamps and out it comes. I doubt the ARB would break if it hadnt done already if it was that bad.Front ARB bushes likely won't come out without snapping the ARB at that age. At least that's what the garage told me last month because mine's knackered! They recommended I get an H&R one and worth getting the rear as well, so just trying to find the £360![]()
Yup, it gives the strut room to pivot around![]()
And after...
Much better, but just wanted to check to make sure a little bit of a gap is normal?
It drives like a pig. Going to get the wheels aligned next week, but it was a really interesting drive. The shifts are just so much more precise with the dogbone in - I can hardly describe it, but there's no notchiness, it just slots in every time.
Steering feels much more precise as well. There was some slack in it before - a bit of play before the steering actually engaged, but now it's there straight away.
I wish I'd maybe done everything one component at a time, so I could say 'that's the dogbone', 'that's the new control arm bushes' or 'the new ball joints had more of an impact' but hey, that's a lot more effort
Scared myself when I turned the engine over though - I must have pulled the gearbox at an angle while I was doing the work, so it meant the clutch was touching the flywheel in neutral ever so slightly for a few seconds. No extra noise or vibration though, and nothing fell off either, so I'm guessing it's all back together properly.
How has your poly kit faired in the year since fitting? Just trying to find out if it's worth doing or not mainly on the lower control arm rear bushes.It drives like a pig. Going to get the wheels aligned next week, but it was a really interesting drive. The shifts are just so much more precise with the dogbone in - I can hardly describe it, but there's no notchiness, it just slots in every time.
To be honest, and this might not be very popular, I can't say I've noticed a massive difference in handling with the polybushes. I think the biggest impact I've had was when I changed the rear beam bushes for polybushes, and even the cheaper ones made the car feel much more planted, but the fronts I can't say I noticed as big a difference as I'd hoped. I was hoping for everything to feel really solid, but while the steering felt less sloppy, that could have been because I changed the ball joints at the same time. I haven't noticed any issues with ride being any more harsh though, and the car's still plenty comfortable while also handling well.How has your poly kit faired in the year since fitting? Just trying to find out if it's worth doing or not mainly on the lower control arm rear bushes.
I have a MK4 Jetta in Canada and a MK1 Leon in Uk and I'm undecided whether to go poly on the rear LCA Bush or R32 lemforder or meyle inserts.
Searching for answers before I fly back to Toronto end of Jan as will be taking replacement LCA's with me bushed ready to go.
