Sl1ced
797
404
It will be full of water.... Will start but miss fire.. cental locking won't work on at least 1 door. 1 flat tyre and rear brakes seized on. . Depending where you live too some one might have nicked the wheels too.
Lmao
Reactions: Yellow fr
iammooks
1,797
1,191
My dad took his locking wheel nuts off the other week. "Everybody has alloys these days - there's no point nicking them."
But then, he has 20" Jaguar wheels...
Reactions: Manic172
Alexis27
2,154
487
Manchester
If the brake fluid looks contaminated,it'll fail.
All they can do is look at the reservoir with a torch. Not allowed to take the cap off during the test.
It was changed 19 months ago, but he said they'll all fail now if they weren't changed in the last 2 years anyway!
Sl1ced
797
404
My car had its mot in November. Brake fluid hadn’t been changed as fas as I’m aware ever. I did it over Xmas
Rich.T
1,609
932
Make his new pimp suit!!
Reactions: BadBoy03 and Sl1ced
Manic172
Dec 4, 2018
1,380
1,452
Hemel hempstead
www.seatcupra.net
"Plus Size Pimp Costume"
If it were me, I'd feel offended...
You calling me fat..... it costs a lot to have this figure....
Reactions: iammooks
Nam-uk
1,200
371
lancashire.
replaced battery 1J0 915 105 AE from theses people https://www.tayna.co.uk best prices and next day, got the varta silver version for 80 quid delivered was looking at excide but specs were better also read there made in same factory as bosch and oem, the on in car is a 70ah varta with a lower CCA which is normal for that time you can still buy it on there but for a few more quid may as well get above, europarts want like 130 for it.
Sl1ced
797
404
Fitted my brace finally! Holes drilled and riv nuts in! Also started to fit new replacements for the catch can setup inc new crank breather elbow and hoses. Also fitted my boost gauge pod.
Half way through making a bracket for the catch can at work! Waiting on for my p clips to arrive.
Excellent day for once
Manic172
Dec 4, 2018
1,380
1,452
Hemel hempstead
www.seatcupra.net
Done nothing on the race car today. But done lower balljoints,drop links and track rod ends on my van. Also oil change on the gearbox too.
Still got front and rear discs and pads. Also a full service too.
Yep I know boring
Reactions: Sl1ced
Connor H
1,032
509
Essex
Waiting for my power flex bushes to turn up... but want to do a gearbox oil change and also reset the shifter linkages
