Hi here is my 2008 Leon cupra 1p 2.0tfsi I got it from my mate who’s had it for over 5 years as his daily. My friend was ready to scrap this car due to it needing so much work and he’s upgraded it for a 4X4 when I got it the Leon was tapping which I called the death rattle it was leaking oil from everywhere and was the worth example of what I’d class as my dream daily driver. I know it’s not flash and anything to shout about it but it was mine and paid for.
So the first week of owning it I had
4 new tyres
Cam belt and tensioner
Water pump
Chain and tensioner
Cam lobe
4 new plugs
4 new coil packs
Fresh coolant
Thermostat
Ac service
Engine mount Polybush insert too
Gearbox mount poly bush insert too
New rocker cover gasket
New pvc gasket
New vacuum pump gasket
And many more gaskets
New wipers front and rear
New pollen filter
K&n panel filter
And probably a lot more I can’t remember now. All parts were genuine VW apart from the air filter and bushes.
This lot took me over a week to do after work bit by bit. Once done the car was back to it former glory and now a good solid car for me to modify into my dream daily.
I drove the car like this for afew weeks and then did little things to it like clean up the inside making sure everything’s worked like door looks etc as they didn’t work at all.
then I decided to chop the middle box out as I couldn’t justify buying a miltek right before Xmas it actually sounded quite good with the middle box out. The following day I had a revo stage1 dome which transformed the car made it a lot more fun to drive to work. My plan with this car is to go stage2+ and replace my track car with it after a few years.
I’m going to get a decent 3 way adjustable coil over setup on it like my track car and get the usual miltek turbo back etc. It shoulda make a decent track car also I plan on replacing the diff with a wavtrac torque biasing item again like my current track car.
There is a lot of things I’m planning on doing to it but this has turned into a essay so I’ll leave it there for now. I have ALOT of photos of things I’ve done it won’t let me upload more then 10.
4 new tyres
Water pump
Chain and tensioner
Cam lobe
4 new plugs
4 new coil packs
Fresh coolant
Thermostat
Ac service
New pvc gasket
New pollen filter
K&n panel filter
