Connor H
1,032
509
Essex
The trouble is that Google tells me there are loads of things it could be - from air still in the system, to a master cylinder that needs replacing, to a split vacuum line. It just seems odd that if I push the pedal a second time, it's firm like it should be, but a few seconds later I'll have to pump it again to get it hard (that's what she said).
My brakes do this by the way and they’re fine, second pump is always harder (oi oi) I got rid of all the brake vacuum stuff though so i thought I’d experience that more now I have no vacuum to help the brakes. Still fine though, aside from them behind pretty pathetic to start with in terms of braking power lol
Reactions: iammooks
iammooks
1,797
1,191
What's it like on the road? I've not done a road test so don't know whether the braking will be improved when the revs are higher, but are you finding as you're driving that you have to double pump the brakes as you're going along?
Sl1ced
797
404
Picked up a mig welder, then on the way back Eml came on. Threw 17704(error in mapped cooling system) now it’s got a brand new coolant temp sensor, maybe the thermostat?
Reactions: iammooks
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
This is what Ross Tech say about that error
17704/P1296/004758 - Error in Mapped Cooling System
Possible Symptoms
  • Cold start issues
Possible Causes
  • Coolant Temperature Sensor (G62) faulty
  • Coolant Thermostat faulty
Possible Solutions
  • Check Coolant Temperature Sensor (G62)
  • Check Coolant Thermostat
Reactions: Sl1ced
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
If it’s soft on the first push and then good on the second you still have a bit off air in somewhere
Did most off the air come out when the piston was getting to be all the way home ?
Reactions: iammooks
iammooks
1,797
1,191
Yes - when the piston was almost all the way home it was still bubbling. Given the number of bubbles and the amount it was bubbling - the bottle I was using to create an airlock was bubbling like it would if you were blowing with a straw - I felt like there was still some air that could have come out. To be honest I don't know why I didn't just jump in the car, pump the brake to reset the caliper and then do it again.
Reactions: Yellow fr
Sl1ced
797
404
Possible Symptoms
  • Cold start issues
Possible Causes
Possible Solutions
Yeah went straight on there and checked it. Like I say fresh temp sensor so thermostat is next
iammooks
1,797
1,191
Don't even talk to me about the bleeding friggin brakes!
The worst job I've ever had to do on this car. The way people talk about it, you think it's going to be so bloody easy, and it's been the biggest source of frustration of any job I've had to do.
Yellow fr
Sep 6, 2018
1,547
1,062
Had to do a puncture repair went to warm the car up just before locking up and noticed I had a flat so pulled two vans out off the work shop and sorted my puncture out
Connor H
1,032
509
Essex
hmmm, I will just say that if I need to stop or slow in a proper hurry I do not need to pump the pedal to do so. Other than that I have nowt to report
Reactions: iammooks
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,245
1,101
Kent
Likewise and I've basically rebuilt the entire car.
They really are an absolute arsehole to do.
Reactions: iammooks
British_Grapher
8
10
Plasti-dipped the chrome grille, left the logo chrome for now to leave a bit of contrast, maybe I'll do the bottom of the bumper instead of a splitter, my new alloys are coming soon which are gun metal grey so should be a nice balance with the colour the car is, I've currently got seats fat 5s on and they're awful IMO. Also added the red round the lights.
Reactions: Rich.T
iammooks
1,797
1,191
I mean, how do you even design a brake caliper that traps the air in it that you're trying to bleed out of it?
And oh, what's that? You want to bleed your master cylinder? You'd better remove your boost pipe, and even then you'll still graze your knuckles trying to get access. Then you'll need a really long bit of tubing to avoid tipping fluid all over your engine bay, but that doesn't matter because when you take the hose off the bleed nipple it'll pour down the side of the master cylinder anyway.
Worst of all, you can't take it to a garage or even two different garages because they won't be able to fix it and will just try to sell you a new master cylinder instead.
I'm telling you, by the time I get this sorted it'll be time to change the fluid again.
Sl1ced
797
404
That’s delicious mate
Thai-wronghorse
Dec 3, 2015
2,245
1,101
Kent
Try my way it does work and it’s easy todo and the feel you get from the pedal will make glad you did it the right way
I intend to when I get the opportunity, hopefully next week fingers crossed
Reactions: iammooks
Manic172
Dec 4, 2018
1,381
1,455
Hemel hempstead
www.seatcupra.net
Personally I would go for powerflex bushes. Been around for years and I have never had a problem.
I am sure they do a standard style polly replacement. Then the purple and yellow up rated stuff then the black series race /Track stuff.
I have gone black series on the leon also have it on my race saxo too .
Reactions: iammooks
iammooks
1,797
1,191
It was the pedal feel that got me. Ever since I bled mine in September, it just hasn't had the same feel - even after having two garages look at it. Today, even though it looks like I've still got a little way to go, that solid feel tells me I'm on the right track.
