SteveGSXR600K1
596
198
Hi everyone, can someone please tell me any update available for my seat leon, thank you.
Device no:5QA035824A
Hardware:h30
Software:0368
SW: 0368 is the latest official version you can go to, but the retrofitters can take you a lot further but would need your unit sending to them.
Domi1410
25
12
Can you let us know how did you update ? I am very interested to update mine as well.
Patch the Unit , modify the Update and then installed.
It can done all remote.
Remote activation of Carplay and Android Auto too :)
For activation you need nothing more as a SD Card.
For Update to Higher Version you need VCP or Odis.
Reactions: lito69
notabenem
62
I have H30 351. So if I read this right, the max I can go to is 368. Will that give me the tiles menu? What other benefits will I get by applying it (having already AA, Sports view,etc., as I own a cupra)?
Domi1410
25
12
You have the tiles Menü already :)
The tiles Menü is inside the 346.
notabenem
62
Indeed, "GRID" menu is there. (strange that I haven't spotted this setting for so many years). But I have realized it also means I can't use the right knob to navigate (which I find so essential).
Aug 26, 2020
11
Wondering If anyone could help, I just upgraded from MIB1 to MIB2. Bought the unit and screen together and everything works fine other than the sound. When I use android carplay the audio is reduced by 50% and there is no bass. It sounds really tinny. The Bluetooth works fine and loud with bass but the bass still isn't as good as the MIB1 system. Does anyone know or heard anything about this before?
Domi1410
25
12
Did you have seat sound system ?
Sep 27, 2020
Hi guys I just uploaded my MIB2 with 0479 version , but I don't see the difference. Can you someone explain to me what is the difference.
Thank you!
Invertigo
169
77
Unsure if this is the right thread, but wondering if there's any updates for me as I seem to be getting odd crashes and Android Auto disconnects that stop once the system is restarted.
Device part: 5F0035877
Hardware: H50
Software: 0514
Slickric21
554
253
Norfolk
Hardware: H50
Software: 0514
0515 is the latest.
check out Eastyorkshire retrofits,
Link in this thread somewhere
Tell
It's not that bad. Ateca dash middle speaker is a base speaker getting on for a sub woofer with the sub woofer in the boot. Unlike surround sound they plonked quite a bit of base where you would find the voice speaker. You got all the rest of the speakers but that sub woofer tending upfront is kind of fun. People on the other Ateca board run by different people use to want to petty squabble about that even thou they didn't option in the Seat Sound system :oops: . The spec was in the SSP, not sure of the Leon 3s set up. Suppose to be tested and tuned up by some research unit at the time.
Rsjay
16
9
You can update up to 0346 not more. For further, your unit must be modified. This is a service and not being done for free.
Sent from mobile
your 0252 not contains all folders,thats why bricked my unit.Dont sell ****...
Oct 24, 2020
Hi everyone, can someone please tell me any update available for my VW e-Golf, thank you.
Device number:3Q0035844
Hardware:h25
Software:0241
Dudept
28
7
Hi there. I have a seat Arona and I want to update the unit version . Anyone knows where I can find the update?
Thanks in advance
Tell
If you look under guides on their site. Like map updates on the high unit you need to keep the power onto it. You could / would run the engine or if you know your battery is up to it just open the car door every 15 minutes, that keeps the unit live. Repeat as required but you might consider running the engine either way like map updates via the SWDL command you dont drop power.
Some on here have done updates that way. I think they are only software packs that a dealer would use but don't. The main thing is not to drop power whilst the process is running. You can only do certain upgrade paths as you read on the thread. Wrong path and you mess things up.
