Manic172
I am going for the minamumlistic style
whats that ? wear or damp?
Oh not good, lucky not got that issue, bet it is a pain as the cover would of been stretched over and pressed in by a machine I reckon , if you do the glue might come though unless you use an adhesive tape like the 3m anti vibration gear.The adhesive's degraded over the years and now it isn't sticking. I'm hoping I can unclip it from the door card and peel it off and put new adhesive under, but I fear that way there will be ball ache.
I am going for the minamumlistic style View attachment 18679
looking on ebay i dont think its worth the faffing at them pricesIt's the only door that it's happened to. No reason for it really, but you're right it'll probably be impossible to do by hand. Because of the shape of it, any adhesive I use would either have to be tacky enough to grab the fabric and stay there, or I'd have to find some way of applying pressure to it until it dried.
I think this can probably go on the list of things that are annoying but can't be fixed without buying a new door card.
Always wondered how this part is removed if you wouldn't mind a brief write up?
All done and back in the car. I'm going to be worrying about chipping the paint for a while, but it's not hard to take out again and respray if I need to - not to mention that I can change colour too. Surrounded by so much black on the interior, I think black was the right choice though.
I was really impressed with the paint finish - you can't tell it's painted. It's the Halfords matt black spray paint, with a couple of coats of Upol primer underneath. Built it up slowly - I think there are about five or six coats on there, so hopefully it's tough enough. It's not a part of the car that'd going to get knocked too often though, so it should be fine.
Took the chance to have a clean up behind there too. It was proper dusty and the thermostat (I think?) for the air conditioning was caked in dust. Sprayed electrical contact cleaner behind the switches to clean the remnants of a coca cola incident too and they're butter smooth now.
Cheers I've got some loose screws it seems, same cupholder issue aswell as the previous owner making the buttons rather sticky i want to clean out
Haha 100% I had the indicator stalks covered in human slime when I bought it. I'll give the electrical cleaner a go. CheersI get the feeling that every previous owner of the Leons on this site were filthy beggars. The number of times I either hear about or come across things like sticky buttons... Someone mentioned on the thread that electrical contact cleaner works well for cleaning the buttons. I gave it a go with the Halfords stuff, and used a fine bristled toothbrush too, and there's no stickiness anymore.
Next step for me is going to be a gear knob and then maybe some sound deadening.
Finding a shift knob that fits seems to be a bit of a pain, so any advice on what I need to look for would be proper awesome.
Bolster foams are still available from the dealer and a few select independent VAG specialists as far as im aware.I'm desperate to repair my driver's seat bolster. It's had the metal support pushing through as long as I've had the car, and it's one of those things I've wanted to sort for years.
All the guides I've come across are years old and the links to the foam padding are long dead. Are there any ways of fixing this these days?
