How solid are these engines when power washing them? I plan on coating mine in gunk then giving it a scrub
Mines a diesel so it’s all good and you don’t need to go close with the jet wash as for one you get covered and the more likely you are to push water into the electrical plugs it’s more off a quick wash over and always do it when engine is warm too and don’t just turn the engine off after make sure you can leave it running to dry itself with the heat off the engine and don’t direct spray on to the electrical plugs is not good but if your hitting it with more off the mist then the actual full spray and always stay away from écus if unsure or nervous bag your plugs and écus
