Pretty sore it requires a software updateHi,
Is there a way to change the dash colour outlines all to red instead of the blue (nav), green (phone) etc?
I'm new to this and have received my OBDeleven device today but before making any changes, is there a way to backup all control units or do I have to do it one by one?
Yeah, just had a look around and it doesn't seems you can backup all control units so I will do it one by one and then backup the control unit after I made changes just in case.Have a look at the Spanish forum
Como hacer un BackUp con OBDeleven. Comparte el tuyo
HACER BACKUP CON EL OBD Es MUY importante hacer un backup tanto ANTES de hacer la primera modificación como DESPUÉS de cada grupo de modificaciones, y...www.clubseatateca.com
Unlike a PC there isn't a restore you have to do this manually.
I'll plug the useful Ateca one at this stage, sister to this on this forum. The top of the thread starts simple but they are the Ateca ones but are / can be common but dependent on component parts then cross reference to German, Spanish and the Obdeleven one. The link above is in the Spanish thread I referenced. It does keep a track of changes. Always best to proceed with care. On Android I take screen shots before and after as well.
OBDeleven Tool for VCDS type of activity... working ones for the Ateca
This thread covers the use of the OBDeleven tool with worked, tested results on the Ateca 2016 - 2019 models. Check Obdeleven website for news on programming the new 2020 models on progress of this "The programming temporarily is not supported on models that are manufactured from 2020 and have...www.seatcupra.net
Best to get the Propack of the next gen. The ultimate just has stuff you dont need like case, extra credits you won't use if programming it. Keep mine in the jiffy pack it came in. I did buy the ring pull one, never use that.I am a complete newbie so admin please apologise if this has been covered loads of times before.
I nearly just bought a OBDelven , then i wasnt sure if i need the pro activation or then the next gen one. and starter pack #confusion.
So i have a 2013 FR TDI i just want to read codes,see dpf regens if possible and also stop the auto start stop and oil service if i change the oil which i like to do every 6k on cars.
Can anyone advise what option is best for the above, really sorry if its been covered multiple times before.
It does say on that screen a requirement is to have the ambient colour function which I read to mean coloured ambient lighting. That is Ateca build code QQ9.
QQ9 VWGROUPLCP Interior ambient lighting, type 2
Type 1 is the non variable colour ambient light unit.
You need to check your build codes to see whether you have type 2.
If you have that type 2 unit it's not unheard of for the some of the built in apps not working. These apps will have been programmed from user identified mods. So that's a Google to find them. I must admit I've never had the urge to change from blue which I set mine too from the default palette in the car. Pretty sure you would have the type 2... just just want to change you pallet.
I see on the Obdeleven you also have some adaptions listed under central electrics. See attached. You might not need long coding if it's been brought out as an adaption defined by the menu settings:
Suggest you look at that in relation to what Google's throw up. Ambient light colour list sounds interesting. I'm off line so can't look at it, dongle not in. So whatever you find on the subject it can probably be adjusted on the ambient key word list, but be careful!.
They like a full scan before edits. Recently the dongle likes to do an update as well. The original white one... so you get a period when it doesn't connect. Then get the dongle software update, then all is fine.View attachment 20254
It worked now! I don't know if it was for this reason but I did a full scan first and cleared error codes then tried to code it and it worked on the second try.
Kids will be happy now. Thanks for your help
