The pedal pumping method is not advisable on these due to the probable chance of rolling and damaging the master cylinder seals
I’ve no idea what it is.Replaced my valve cover gasket. I had visions of it being a fiddly job, but it all went pretty smoothly.
Biggest pain in the bum was getting the cambelt cover back on. Whilst doing that I found this item near the engine mount. What the hell is it?? Too short to be the cambelt!!Is it some sort of hose tidy?
Yep, oil drips on my driveway. It was leaking out of this halfmoon section and rear corner on the right hand side of the valve cover. Oil all over the gearbox and undertray.I'm getting mine done tomorrow because it's weeping oil. Did you have any particular symptoms?
Deposit for a BMW M3......SORRY GUYS please don't boot me off the forumI drove about 125miles.... gave a pile.of money to @Nizza.(Top bloke by the way with some quality stuff for sale. ) put some bits in my van then drove 125 miles back....
Hope you didn't impact gun the top strut bolt. I've heard this can ruin the internal seals.Took my front shocks out and apart greased it all up and impact gunned it back together, think I’ve cured the knocking noise now. Also shorted my drop links 10mm.
I've never actually torqued one to spec for fear of blowing seals. The first nut im sure goes onto the non threaded section so you cant really over tighten and the top nut i just get as tight as I can with a handled allen key and adjustable wrench on a spark plug socket.Only if it spins the main shaft. You can clamp the shaft as hard as you absolutely can with vice grips first which helps get the nut back on. They're very hard steel with a hard chrome coating so it doesn't even mark them (in my personal experience anyhow).
I'm really interested in hearing your opinion on what the ride height is like one you've got it all fitted, seeing as my ride height increased by about 10mm with this same setup?!?!Started at the easy end with my new suspension kit by replacing the rears trying to get them on before i started work. Starting at 7.15 on my dads drive way i was back home for work at 9.15 so i'll call that a result. Has definitely taken some of the crashiness out of bad roads with less rattling from the rear in the cabin whilst also feeling more planted. Fingers crossed the fronts go OK later in the week.![]()
Will do, should all be on by Thursday. I'm honestly quite happy if I end up same ride height but newer, better ride quality and less roll as the stock car catches most speed bumps when my lowered gt86 doesn't hit anything. I cant even get it down a ramp to my garageI'm really interested in hearing your opinion on what the ride height is like one you've got it all fitted, seeing as my ride height increased by about 10mm with this same setup?!?!
