Whiteline front arb / droplinks question
Cuppyjoe
97
20
On another note, had to wind the coilies up a bit today to prevent the ARB hitting the driveshaft until I can afford the new ARB. Loads of thread to go if I did want to really slam it
Reactions: Connor H
Connor H
1,023
503
Essex
@Cuppyjoe
Ah yeah, i just changed from that set up because of that reason lol. You'll prob need a diff anti roll bar with bigger hoops (which i thought was pointless) or switch to the setup i have. I dont know if adjustable links will help in this situation as i didnt look into that.
my ARB cost me 20 quid off ebay, 5er for oem bushes and 30 quid for the drop links. Well worth it.
Connor H
1,023
503
Essex
The whiteline one goes under the driveshaft and is made for the (non R) set up. whiteline ARB
The fact TT/s3 ones fit the same, are in easy supply and are much cheaper was enough for me. TT one I have is only 20mm, so less stiff, but I plan to get a stiff rear ARB to balance it. I’ve heard a stiff front ARB on this platform can induce understeer quite bad.
All depends on your budget!
Cuppyjoe
97
20
That sounds like something I can get on board with, would an s3/tt one fit to my current set up?
Connor H
1,023
503
Essex
Yes mate, MK1 TT and s3’s are a good resource for bringing the AUQ platform (mine is same as yours) up to snuff with the LCR etc.
Just had a quick look on eBay and no super bargains right now, but there’s usually a few kicking about.
When choosing just be sure to pay attention to the diameter/thickness of the bar so you can get the right bushes.
Connor H
1,023
503
Essex
Forgot to add if you’re wanting to do this, you WILL need the mounting point on your suspension, as seen in my earlier pictures. I have LCR coilovers for this.
Nizza
380
234
Just buy my roll bar drop link set up...
Oh and an awesome kw clubsport set up
Sent from my SM-G988B using Tapatalk
Reactions: Connor H
Nizza
380
234
Think this is an s3 / tt roll bar. New custom drop links at 30mm.
£30
