I thought that someone had confirmed that at some point in time, these bags started to get replaced with a better form of container for the silicate granules - I thing that I read that in this forum, as to what exactly that means to those without "mit silikat" or just the original bags that might just break open, I can't say, just another variable to add into the increasing slight confusion - with still no good trustworthy "resource" quality statement available.
Using facts from Halfords or ECP to select a version of VW Group equivalent coolant is at best very risky, if collectively "we" can't get a good grip on this, they certainly will not.
Edit:- I'd expect Halfords and ECP just to correctly suggest which by build date, or very roughly by reg date, version of G11, G12, G12+, G12++, G13 VW Group could/should have used at initial factory fill. I'd doubt if G12evo is on many aftermarket suppliers lists yet, but will get quoted by the supplier of the base coolant that VW Group uses.
So I understand that it’s supposed to be g13 in my car? However it’s a pink colour which I believe should be purple? Any idea if I need to top it up a pink colour OAT for Halfords or ECP might be alright?
