Cupra facelift with copper bits from eaziwrap?
Adrian300
259
113
Have any of you guys got pics of your cars with the copper inlays for front bumper scoops, badges, cupra letters, and mirror caps. I have monsoon grey cupra st and want to see what they look like. Thanks
Sent from my GM1913 using Tapatalk
Adrian300
259
113
Had a look on there but a lot seem to have been taken with filters etc, just wanted to see how it looked under normal conditions daylight with no filtets etc.
Ive now ordered copper "S" badge inlays, the bumper scoop inlays cupra lettering and wing mirror tops. And the fitting kit he sells.
Hopefully dont mess it up when installing lol.
chouffe
26
15
There is no particular filter on my pictures. If you need to see something closer just let me know !
OJ9693
Mk3 Leon FR 150
Sep 2, 2019
284
56
You could try masking it up and using plastidip? It's what i recently used for the bumper insert on the back to make it look black.
From what i've read, it doesn't mess with your parking sensors. As long as you don't apply too many layers.
Adrian300
259
113
All good and yes can tell yours have no filter. Made my mind up and got it all ordered. Not 100% sure on wing decals yet... Although a lot more discreet than i thought looking at your pics @chouffe
Chris99
9
Could someone please give me their advice, I’ve had a p0234 on my 2010 Leon 2.0 tdi sport and going into limp. Vacuum checked all pipework and corresponding components and all hold vacuum. Actuator arm moves turbo vanes. Only thing I noticed is when vdcs testing boost solenoid vacuum is 25” idle the same as the vacuum pump is creating but when not being tested I’m only getting 16.5” idle. Might be normal but I assume I should have 25” vacuum when the Solenoid valve is on. Could this be the ecu being sent wrong information by MAP or MAF sensor?
Adrian300
259
113
U may want to create a seperate post on this. People with the knowledge wont see this here.
Cupra_Jay_300
Now: Magnetic Grey 290 LUX. Then: Nevada White 300
Jan 25, 2018
74
40
I did have the bumper inlays but I ended up fitting the Cupra R grills instead. Have a look at my Instagram for pics - ha11_cupra
Adrian300
259
113
Fitted the bumper inlays, badges and mirror tops, pretty pleased with how its turned out.
