Cupra 300 st with mk7.5 golf estate exhaust
Jan 21, 2020
10
France
Norbert
395
98
So just fitted the r exhaust on 2019 cupra dpf. Easy just need one cut and sleeve clamp.
Sound the bit loud but i will see.
CupraNJ
110
40
Bristol
I realized I never put any after pics with the whole thing fitted and clean, so here you go:
You call that clean! Those exhaust tail pipes are filthy! Only joking, looks great. Looking to fit Golf R back boxes next month.
Reactions: Jaco2k
Fer16v
65
18
Spain
One question guys. So....if an R estate exhaust is valid for our st's in terms of clamps and dimensions.....the Akrapovic model available from the Golf will fit ours too??? Even in our +19 GPF ST/R versions???
Regards.
Jaco2k
AWD FTW
Mar 11, 2018
1,048
643
Tampere, Finland
www.youtube.com
TBH, the guy that cleans my car could not do better than that - there is a lot of baked carbon.
Whoever owned the donor car probably never cleaned them.
When I have time and patience at home I will give them another go, but you should have seen what they looked like!
Adrian300
259
113
Regards.
Not 100% sure they the the akrapovic on the estate R
Sent from my GM1913 using Tapatalk
Fer16v
65
18
Spain
As f
As far as i'm concerned is an aftermarket option directly from VW dealers. AK doesn't sell it directly to customers. AK was stock Exhaust in the 7.5 Golf R Performance Package. I believe both 5dr & State versions.
Regards
Adrian300
259
113
Yes i know it was a factory option, just not 100% sure it was available on the estate version.
Jan 21, 2020
10
France
Finally, I hope for a similar line as a friend, home made in stainless steel by a local supplier. I just get back the car, need to wait to try it on long way, if needed, I will add short muffler.
link from a video from the guy who made it
Pictures can be sent if you want
Reactions: jt20vt
Mar 23, 2020
Hi Norbert,
could you please describe what does "bit loud" means? You mean loud outside or inside?
Do you have middle resonator or just Cat -> GPF -> back boxes?
I'm going to fit the R exhaust to my Octavia RS with GPF, so it think will be pretty much the same result like in GPF equipped Cupra.
Thanks,
Robert
Norbert
395
98
H
Hi Norbert,
Thanks,
Robert
Hi Robert
Mine gpf car so no mid box fitted.Exhaust sound much deeper and louder too.just enough loud too me.Shame no exhaust valve fitted because sometimes i want less noise after long day.Plus side when system warm up properly good dsg farts and another banging follow in sport or cupra.
this is cold start with higher rev.idiot gpf car do it every start no matter water temperature full warm and car just parked 10mins.
Mar 23, 2020
H
Hi Robert
Thanks Norbert!
What about motorway speeds? No drone inside? Much louder than before?
Norbert
395
98
Thanks Norbert!
Louder and possibly same level as r estate inside. you can check some YouTube golf r estate inside video.
I hardly use motorway,city car for me but not so bad around 90-110 on motorway.my car sound insulated (doors,boot and under rear seat)so thats help however st interior louder or echo sounds(i cant find better word.my “little english”)
