Yes, it should look like that. Maybe @S4BiT can confirm this?Nice job, thank you very much for that
for the golf box, it looks like that?
like here? where it seems also that the outlet piping is not fix to the muffler.If you prefer the oval exhaust you could use the mk7 golf r estate exhaust. It has one exit either side but is just as loud. Just cut and weld the ovals to it?
https://www.ebay.co.uk/itm/2016-Vw-Golf-R-Down-Pipe-Exhaust-Cat/254147566459?hash=item3b2c601b7b:g:0BgAAOSwHSdcEEOp&LH_ItemCondition=4
You call that clean! Those exhaust tail pipes are filthy! Only joking, looks great. Looking to fit Golf R back boxes next month.I realized I never put any after pics with the whole thing fitted and clean, so here you go:
Not 100% sure they the the akrapovic on the estate ROne question guys. So....if an R estate exhaust is valid for our st's in terms of clamps and dimensions.....the Akrapovic model available from the Golf will fit ours too??? Even in our +19 GPF ST/R versions???
Regards.
Sent from my GM1913 using Tapatalk
I've not seen an estate version... But would of been interested in one.Yes i know it was a factory option, just not 100% sure it was available on the estate version.
So just fitted the r exhaust on 2019 cupra dpf. Easy just need one cut and sleeve clamp.
Sound the bit loud but i will see.
Hi RobertHi Norbert,
could you please describe what does "bit loud" means? You mean loud outside or inside?
Do you have middle resonator or just Cat -> GPF -> back boxes?
I'm going to fit the R exhaust to my Octavia RS with GPF, so it think will be pretty much the same result like in GPF equipped Cupra.
Thanks,
Robert
H
Hi Robert
Mine gpf car so no mid box fitted.Exhaust sound much deeper and louder too.just enough loud too me.Shame no exhaust valve fitted because sometimes i want less noise after long day.Plus side when system warm up properly good dsg farts and another banging follow in sport or cupra.
this is cold start with higher rev.idiot gpf car do it every start no matter water temperature full warm and car just parked 10mins.
Louder and possibly same level as r estate inside. you can check some YouTube golf r estate inside video.Thanks Norbert!
What about motorway speeds? No drone inside? Much louder than before?
